Old August 8th, 2007   #1 (permalink)
ishpalsingh's Avatar
Default ho do u add backgrounds
although i can very well render models with material and lighting effects but i am not good at adding backgrounds.i know photoshop to a good extent, so many people here have told me to use google images to pick the foliage and other stuff but they are generally of low resolution which cannot fit inside my renders. I think photoshop gives better results in short time, i need tips on finding the images that match the resolution or tell me how do u do it
ishpalsingh is offline
Old August 9th, 2007   #2 (permalink)
STRAT's Avatar
Wales
Default Re: ho do u add backgrounds
you go out there with your digital camera and custom shoot your own hi-res images and bits and bobs. if you only rely on google images for your imagery you'll never progress to your proper potential.
STRAT is offline
Old August 9th, 2007   #3 (permalink)
i don't think everybody clicks from their surroundings
that means we don't have any other method?
Old August 9th, 2007   #4 (permalink)
STRAT's Avatar
Wales
scan in images from magazines/books then. It's just a case of using your noddle
but there are royalty-free photostock web sites out there. and besides, if you're rendering a specific job you should have access to specific backrounds from the client or your job resources anyway. it's not often you'll need a random backround.
take a look at the textures resource thread too
STRAT is offline
Old August 9th, 2007   #5 (permalink)
IC
IC's Avatar
Scotland
Ambient Light do very cheap packs of textures for foliage etc.
http://www.ambientlight.co.uk
http://iainc.carbonmade.com/
IC is offline
Old August 9th, 2007   #6 (permalink)
bigroo's Avatar
England  Send a message via MSN to bigroo Send a message via Skype™ to bigroo
Wink Re: ho do u add backgrounds
Either that or fly to a suitable environment. (We have many cheap flights in Europe).
All things in nature are dark except where exposed by the light. Leonardo da Vinci
bigroo is offline
Old August 11th, 2007   #7 (permalink)
how many dpi do u think is best for that type of scanning
i have done it at 150 dpi it omes noisy(colored dots)
Old August 11th, 2007   #8 (permalink)
JonRashid's Avatar
Wales
When you get your foliage image. Cut a rough opacity map in photoshop and place a board in your max file. These can be very rough as they are very easy to tidy up in the final image. This helps tie them into the image by casting shadows within the scene.
JonRashid is offline
Old August 15th, 2007   #9 (permalink)
sterealkey's Avatar
Name: Piet de Wet
South Africa  Send a message via MSN to sterealkey Send a message via Skype™ to sterealkey
If you scan from a magazine that was litho printed you will see those dots, in the print industry they call them moire patterns.
If they are not too hectic, then you can use your 'remove moire' or 'despeckle' tools in photoshop. But generally I wouldn't recommend scanning from a magazine.
Its best to rather take real photographs. Its a fun outing if the actual site is not too far away. I often draw inspiration from it.
We are actually busy working on a job that we have to do an animation for. Its a development on a farm, so we want to go camp there to see the sunrise, and record the animal sounds and do a full analysis of the magical mood that it has to offer.
You might not wan to go to that extreme, but its an example
www.ocellus.co.za - innovation in design, illustration and visualization
sterealkey is offline
incremental add to current map irradiance map settings Boing General Discussions 9 July 25th, 2007 11:32 AM
What to do...What else to add? Dave Bond Work in Progress (WIP) 12 October 27th, 2005 04:03 PM
Add a "custom tool" to "My tool Catalogue"? archkre AutoCAD/AutoCAD Architecture 6 August 18th, 2005 05:15 AM
Best way to add Hills/Valleys to large flat surfaces? MegaPixel 3ds Max 3 May 9th, 2005 01:59 PM
add more sides to objects.... kunstraum.tv FAQ (Frequently Asked Questions) 2 March 15th, 2005 04:37 AM
