Autodesk VIZ Autodesk VIZ
Old August 13th, 2007   #1 (permalink)
Aaron2004's Avatar
Name: Aaron Nordstrom
Default Extruding Polygon
Hello,
I have battled with this for a while and I finally found time to ask a question when it came up. I want to extrude the highlighted polygon out to form a step...but doing so will force it to overlap with the face to it's right. What is the cleanest way to extrude this?
I know it's really no big deal if it does overlap, but it makes the model feel more chaotic and when I unwrap the UVWs to export it to a real-time engine, it just makes it more confusing.
Thanks!
Aaron
Aaron2004 is offline
Old August 13th, 2007   #2 (permalink)
JonRashid's Avatar
Wales
Default Re: Extruding Polygon
Extrude it and the polygon to its right. Then you can weld the vertices on the right that are not necessary.
JonRashid is offline
Old August 14th, 2007   #3 (permalink)
South Africa
or delete polygon to the right and extrude first polygon then weld end vertices.
Or the reverse, delete the step polygon ,cut right hand polygon on desired step line and extrude that part across deleted polygon to end and weld.
There is no fast way to do this.
foxlee is offline
Old August 14th, 2007   #4 (permalink)
Aaron2004's Avatar
Cool...thanks guys. All those suggestions are what I have been doing before. I was just hoping that one of the many options in the 'face' subobject would help out. Guess not!
Thanks.
Aaron
Animating low polygon people in C4d transformav Cinema 4D 19 March 14th, 2007 11:43 AM
polygon meshing proces2 General Discussions 3 June 6th, 2006 10:06 AM
C4D polygon limits? josephus Cinema 4D 1 May 7th, 2006 10:16 PM
polygon count increase (lock mesh set), why ? Lioric Lightscape 4 August 23rd, 2003 01:15 PM
polygon modeling proces2 3ds Max 4 May 16th, 2003 10:47 AM
