Old August 21st, 2007   #1 (permalink)
Greece
Default Autocad to Maxwell
Hi Maxwell users.I am an autocaD user.I am trying hard to learn maxwell render and i think i am close but i have a specific problem.I am modelling in Autocad but i can not understand hot to map the geometry so that i can apply the materials and the textures when i am using the maxwell.
Does anyone have a solution to this workflow problem?
Thanks so much in advance
mimoutis is offline
Old August 21st, 2007   #2 (permalink)
Maxer's Avatar
Default Re: Autocad to Maxwell
I wish I could help but I don't use AutoCAD, you should post your question on the NL Maxwell forum if no one responds here.
“There is no spoon”
Maxer is offline
Old August 22nd, 2007   #3 (permalink)
There is no plugin for autocad still. You must import your geometry into Studio, and then, apply materials and use the projectors, which are located in the object properties panel. There are basic mapping modes. Very intuitive.
renato is offline
Maxwell Render 1.5 Maxer Maxwell Render 205 August 4th, 2007 01:59 PM
Yay, this renderer works like CRAZY Bongo51 Maxwell Render 13 July 20th, 2006 10:30 AM
Maxwell Announcement Maxer Maxwell Render 24 March 16th, 2006 02:03 AM
Maxwell 1.0 Release is pushed back again Maxer Maxwell Render 464 December 20th, 2005 01:25 PM
