Old August 23rd, 2007   #1 (permalink)
Default Loft mapping bug????
I have lofted a wall around the perimeter of a room and i want to use loft mapping to texture it. As the mapping approaches the corner of the wall it begins to distort - its fine in the centre of the wall (or segment of the path).
any ideas how to stop this? Im sure it didnt used to happen in older versions of max...
markygl is offline
Old August 23rd, 2007   #2 (permalink)
stef.thomas's Avatar
Scotland  Send a message via Yahoo to stef.thomas
Default Re: Loft mapping bug????
Try right clicking the Camera label in the top left of your viewport and turning on 'texture correction'. Not sure if this will sort it, but I remember reading it in one of the tutorials that ships with max.
stef.thomas is offline
Old August 23rd, 2007   #3 (permalink)
thanks stephen, but its a render problem too.....
markygl is offline
Old August 23rd, 2007   #4 (permalink)
Dibbers's Avatar
England  Send a message via MSN to Dibbers Send a message via Skype™ to Dibbers
Try adding more segments to your path, or adding extra vertexes either side of the corner.
Hard boiled eggs and nuts....Mm!
www.idenby.co.uk
Dibbers is offline
Old August 23rd, 2007   #5 (permalink)
i have encountered similar issues, when I create a sloping roof using loft..
I just resolve the issue by overriding the loft mapping with separate planar uvw mappings to each side of the loft..
if there is any other solution.. i am all ears..
with regards
Mr. Samir Jadhav
Architect & 3d Animator
jadhav333@yahoo.com
jadhav333 is offline
Old August 23rd, 2007   #6 (permalink)
with regards
Mr. Samir Jadhav
jadhav333@yahoo.com
Old August 23rd, 2007   #7 (permalink)
nazcaLine's Avatar
Peru
maybe a smooth problem? there are some options for smooth path and smooth shape.i used to have some problems because of that.
Eduardo
"I have nothing to do with the real world anymore. Please don't insist."
Eduardo Romero
nazcaLine is offline
loft and mapping Chad Warner 3ds Max 6 August 6th, 2007 08:03 PM
UVW mapping question. salf 3ds Max 3 July 15th, 2005 01:40 PM
MAJOR bug in brick material or UVW mapping????? quizzy 3ds Max 4 June 8th, 2005 02:14 PM
mapping gizmo transformation !!?? virses 3ds Max 1 September 21st, 2004 05:07 AM
loft, loft and more loft!!!! radioVOY Hardware and Technical Discusions 2 August 15th, 2004 10:47 PM
