Autodesk VIZ Autodesk VIZ
Old September 18th, 2007   #1 (permalink)
Default Church Night Render
This is a work in progress, & for the time being mainly for the designer to determine if he has choosen the right lights. But will eventually be shown to the client. So at this point the scene has not been materialed much. The original model was created by someone else in sketchup.
This is the first night rendering I have ever done, so I would appreciate any criticism or suggestions. I used IES lighting. Ther are 14 sconces on the columns, 2 in-grade spotlights aimed up at the cross, & 2 floodlights on either side of the roof aimed up at the cross. I used vray dome light with a dark blue & .1 multiplier. I have a Vray plane light w/ a multiplier of 100 (to simulate parking lights). Im also using Vray's Physical Camera with Fstop-8, Shutter- 2, & ISO-100.
I'm also working in linear workflow, using VIZ 2008, & Vray 1.5 Final
Thanks,
Data from the U.S. Energy Information Administration illustrates that buildings are responsible for almost half (48%) of all GHG emissions annually. Seventy-six percent of all electricity generated by U.S. power plants goes to supply the 'Building Sector'. Therefore, immediate action in the Building Sector is essential if we are to avoid hazardous climate change.
http://www.architecture2030.org
denham is offline
Old September 18th, 2007   #2 (permalink)
mbowers's Avatar
Default Re: Church Night Render
you need more light. You have a full moon (which shouldn't be blurry) that provides far more light that most people would think. Bump that up and then adjust your lights from there.
mbowers is offline
Old September 18th, 2007   #3 (permalink)
Maxer's Avatar
I always approach night renderings by establishing what time of day or night the rendering is going to be and then setting my exterior ambient light levels to match. This is a very important step because no matter how dark the night is you will always have ambient light around your building unless you’re out in the country. Get your light levels up so you can see at least 75% of your building and then start tweaking all of your spot lights. Use reference images of night shots if you need direction.
“There is no spoon”
Maxer is offline
Old September 18th, 2007   #4 (permalink)
actually this is out in the country, so there is relatively no city light pollution.
I'm working on increasing the ambient light though. I'l post a revision tommorrow.
Thanks for the insight.
denham is offline
Old September 19th, 2007   #5 (permalink)
Frosty's Avatar
United_States  Send a message via MSN to Frosty
Devin is bang on the money. This is the third night rendering I've seen on here in 3 days. ALL were far too dark. A night rendering should not be black. It should be high contrast and it should have cool (blue/purple) ambient light. All of your light fixtures should lean heavily to the orange side of yellow.
The suggestion to view stock art is important and should be followed for most renderings.
Steve Shaw, M.Arch
www.crucialperception.com
Frosty is offline
1.5 final HAS BEEN RELEASED tdarcy VRay Render 13 August 9th, 2007 11:24 AM
V-Ray Version 1.5 Officially Released! Jeff Mottle CGA News 1 August 9th, 2007 05:48 AM
Night render on water. tasi55 3ds Max 6 August 8th, 2007 06:59 PM
Night render with Mental Ray tasi55 Mental Ray 2 August 8th, 2007 07:15 AM
Render Elements Crash lebbeus 3ds Max 0 December 5th, 2004 10:51 AM
