Autodesk VIZ Autodesk VIZ
Old September 22nd, 2007   #1 (permalink)
Saturn's Avatar
Default UV mapping along curved surfaces
Hey everyone. I am working on a project that has pool deck with a lot of curved paving patterns. Is there a way to map the UV along the curves? Or do I have to model each paver? I am modeling with Sketchup and rendering with Viz and Vray.
Jason Matthews
Saturn is offline
Old September 22nd, 2007   #2 (permalink)
Chad Warner's Avatar
Default Re: UV mapping along curved surfaces
Best bet for that would be to create the path lines in sketchup and then use those lines with either the sweep modifier or a loft, and have the sweep generate mapping coordinates. You may have to adjust the tiling in the map to get the right scale on each paver.
This method works real well unless you have a curve followed by a sharp corner, in which case the mapping gets screwy.
Chad Warner is offline
Old September 24th, 2007   #3 (permalink)
Saturn's Avatar
Thanks Chad
Jason Matthews
Saturn is offline
Old September 24th, 2007   #4 (permalink)
gfa2's Avatar
Yeah, coming from an outside program (sketchup, autocad, etc) you never get proper UV's. Modeling them in max/VIZ is definitely the answer.
gfa2 is offline
UV mapping warprat Lightwave 5 October 11th, 2006 05:52 PM
Curved Walls drvox 3ds Max 4 October 5th, 2006 07:21 PM
UVW mapping question. salf 3ds Max 3 July 15th, 2005 12:40 PM
Mapping a curved road rcase 3ds Max 4 April 10th, 2005 02:16 AM
mapping gizmo transformation !!?? virses 3ds Max 1 September 21st, 2004 04:07 AM
