Old September 25th, 2007   #1 (permalink)
Bwana Kahawa's Avatar
England
Default Losing Textures in Job Queue?
Hi,
I've recently managed to get a job queue working in Maxwell on my Mac, but each time it gets going, it completes about 3 renders before failing the fourth.
Each time it says it fails, it can't find one of the textures. However, the renders are all separate camera views of the same model, so there's no reason why it should suddenly fail to find the texture.
Anyone had experience of this? Is there a limit to how many renders you can place in the job queue? I'm trying to get an animation out so it'd be great to get this working!
Cheers,
Derek
Bwana Kahawa is offline
Old September 27th, 2007   #2 (permalink)
Maxer's Avatar
Default Re: Losing Textures in Job Queue?
You’re talking about rendering out an animation correct not a bunch of stills? As far as rendering and animation out goes there isn't a limit on how many frames you can render in a sequence. Does it always fail on the same view or is it a different one each time?
“There is no spoon”
Maxer is offline
Old September 28th, 2007   #3 (permalink)
England
Yeah, it's a series of frames of an animation, although I couldn't get the animation to work through the Form Z plug-in, so I've fudged it with essentially a series of camera views in the same model.
It doesn't always fail on the same view - it seems to fail on around the 5th render in each queue, regardless of the content of the frame. The textures are in the same folder as the MXS file.
Once I set the queue going again from the failed view, it always finds the texture fine and happily completes the render, finally failing on whichever render is roughly 5th in the queue after that!
It's as if Maxwell has a limit on the number of renders that can be queued successfully. Any ideas?
Old September 28th, 2007   #4 (permalink)
Maxer's Avatar
I've done many animations with Maxwell that were exported from Max and I've never had the problem you’re describing. I'm not sure how the Form Z plugin works but if it's like Max you specify a range and then the plugin exports one MXS file for every frame of your animation. Then you load the first of the MXS files in the Maxwell viewer and specify the range of animation. So if you have 100 frames you'd enter 0-100, then everything is pretty much automatic at that point, if one frame fails to render I will go back and just render that single frame by it's self.
“There is no spoon”
Maxer is offline
Old September 28th, 2007   #5 (permalink)
England
Sounds ideal, but unfortunately if one fails then all the renders following also fail. Meaning it can't be left to process overnight. Very annoying!
Backburner Job Share Thox 3ds Max 0 May 23rd, 2007 03:25 AM
New CGarchitect.com Job Board Just Opened! Jeff Mottle General Discussions 20 September 29th, 2006 07:15 AM
Losing textures and maps in big renders. kiajoon VRay Render 5 March 10th, 2006 04:03 AM
Job seeker poll ihabkal Polls 0 May 10th, 2005 05:34 PM
Stone textures dmedraft General Discussions 6 April 15th, 2004 04:28 PM
