Name: Franklin Bryant |
I have a couple of questions to ask you guys.
Do I need to do a Radiosity Solution to use the Regather direct Illumination? And If I do what are some good numders to start off at? Because when I use it with a solution my seen is blown out. |
Hi Frank,
It's a bit long to explain the workflow here, but I suggest you read the radiosity workflow in the manual. rgds nisus
Guest
Posts: n/a
yes u need to do a Radiosity Solution to use the Regather direct Illumination? but no meshing is needed and usully u don,t need a high Radiosity Solution to get a good results a 25% is good number to start with u also need high filltring number to get red of blochness 10 is good number to start with
hi all,
the manual even claims that you can have the refinement on 0% without any meshes... (I don't agree totally, but hey... who am I?) nisus
The way the radiosity engine works is bizarre. Sometimes the image looks so much better id you have regather on. clamp values at around 500 to 1000 but if i chuck another object in like a chair etc. then hit render without resolving, it looks fine. when igo back to resolve it looks the same but also without regather on. It sems to have a mind of its own
Hi matt,
Many researches brought up the following conclusions: a simple model with only walls and holes results in a more accurate lighting simulation than a complex model because light got less scattered over all kind of smaller objects. rgds nisus
