Autodesk VIZ Autodesk VIZ
Old October 9th, 2007   #1 (permalink)
Default material: ray trace glass
Hi,
I did one exterior glass material based on Ted's tutorial idea. It contains fall off map, raytrace map and others.
For the small object testing, it looks convincing. But when I put it for large curtain wall, it takes foever to render.
I think I am not naive to the raytracing rendering. I experience main Raytrace lighting Quadtree Depth from 10 to 7. In the render scene pup up, under "Raytracer Global Parameters", I set Ray Depth Control's Maximum Depth to 2. Under "Global Raytrace Engine Options", I only left "Enable Raytracing", "enable self Reflect/Refract" selected. But it is still slow.
What else I should do?
I will post the glass material later if anyone want to see it.
smr_VIZ is offline
Old October 9th, 2007   #2 (permalink)
Default Re: material: ray trace glass
Anyone with knowledge please help. I will give my efforts to help you guys later.
Thanks again.
smr_VIZ is offline
Old October 16th, 2007   #3 (permalink)
RAYMOND's Avatar
just curioius...
what is your platform...
what you doing sounds like a processing hog
I have a slow pc also (at least for rendering ws)
so i avoid complex raytracing which is unfortunate
also, don't know if you are using daylight system.... if so turn the sky lite off this really adds time
this probably doesn't help much... but i feel your pain
ray
honolulu
RAYMOND is offline
mental ray glass material smr_VIZ Autodesk VIZ 2 October 7th, 2007 08:36 PM
mental ray: glass material smr_VIZ Mental Ray 1 September 17th, 2007 04:04 PM
Glass Material / vraysun Light & Shadows drvox VRay Render 3 May 30th, 2007 10:06 AM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 10:34 AM
glass material - glossiness level skorn Autodesk VIZ 0 October 2nd, 2003 10:13 PM
