| Autodesk VIZ Autodesk VIZ |
#1 (permalink) | |
Name: Lode Blomme |
Found on http://www.cgtechniques.com
Anyone that has a sollution for it? I've tried everything ... (exept regathering, seems like my PC can't handle that, VIZ4 hangs when I try to render with it ...) And if you ask me, Lightwave scores best in that content. Man, what a results ! Super realistic ! Not even 1 VIZ4 image in the contest where I think : "Hmmm, is that a photo or a CG image?" I hope Autodesk fixes this soon! |
Name: Stephen Leworthy |
well i've not yet used viz 4, only viz 3, but try this -
1) supersampling - try messing with these settings for the main material 2) material filtering - the standard is set to pyramidal, change this to summed area with a value of 0.5 Try this for both diffuse AND bump channels. 3) rendering filters - try a different render filter other than the standard area filter. try catmull-rom maybe. |
Hi SAMP!
U should use Radiosity Override in Material Editor. Try to change Indirect Bump Map Scale. Set this parameter much below default. The value between 0,2-0,4 often causes ViZ to produce nice (acceptable I mean) results. Best regards.
.:: regards ::. Wojciech Klepacki |
Name: Franklin Bryant |
It looks like you need to set your refine iterations (all objects) higher. 2 is always a good number. It may take a little longer for the solution to run. But I think it should fix your problem.
Hi Frank
I thing that refining iterations won't help, when u use regathering. I suggest u to decrease indirect light bump scale. Best regards. P.S. Here is nice tutorial http://www.alexcasanova.com/ (tutorials section)
Indeed wojcieh. Refining won't help when using regathering. Decreasing the indirect light bump scale will get the job done.
nisus
Name: Lode Blomme |
I cannot use regathering since my VIZ4 hangs then on my old crappy PC
Btw, the example image here is NOT mine! But I have he same problems. And usualy I take 3 for refine itirations, so that'll do |
