Name: sankar srinivas |
hi.....
i am working out on maxwell from day1.....until now i haven't succeeded in getting rid of noise in maxwell images.......i have played with all the settings like f-stop, shutter speed, and film ISO.....i have also added lights and proper light intensity to them..... please go through the attached images and let me know about the render and light settings..........where am i going wrong....... thanks in advance and cheers nivas. |
Name: Devin Johnston |
There are many things you can do to reduce the noise in your renderings, however Maxwell is quite possibly the slowest render engine on the planet and you should be prepared for very long render times especially when dealing with interiors. I use 10 dual core machines rendering in cooperative mode to render out all of my Maxwell scenes, at a resolution of 3000x2550 I can get an interior scene to an SL of 16-17 in about 15 hours. This is the equivalent of rendering on a single dual core machine for 300 hours.
-Make your emitting surfaces as lowpoly as possible. -don't enclose your emitters in a dielectric object if possible -Make sure the emitter isn't intersecting other geometry -don't use pure white (255, 255, 255) in your scenes try something like (233,233,233) because the pure color will increase the amount of noise . -use AGS glass where ever possible -unless you need them turn off caustics -don't use sunlight and physical sky, a HDRI or skydome with a sunlight emitter will produce much less noise. -hidden emitters can reduce noise |
hi maxer.....
wt does this sentence mean????? "hidden emitters can reduce noise"...... and also please tell me smething about the scene scale......does it realy effect the lighting output in the image??????? my scene is in feets and inches.....i have put .254 value....is this value correct????? cheers nivas |
Name: Andrew Dehus |
Maxer, I thought .254 was correct for feet/inches. Isn't Maxwell set to calculate based upon the metric system?
I've been told this for the FormZ plugin, maybe others are different? |
Even i too was been said before that .254 scene scale is must for feet and inches scene.....
now watz this..??? how to decide on scene scale for a particular type of max scene.... please advise.. nivas |
| Maxwell Render 1.5 | Maxer | Maxwell Render | 205 | August 4th, 2007 01:59 PM |
| SU model and Maxwell Materials | michael557 | SketchUp | 20 | February 17th, 2007 08:13 PM |
| Microstation + Maxwell WIP image | Phil Shields | MicroStation | 5 | December 12th, 2006 12:14 PM |
| Viewport Image Problems | MesaPrs | Autodesk VIZ | 3 | November 21st, 2006 08:21 PM |
| Maxwell vs. Vray Experiences/Advice | thickly | General Discussions | 15 | October 10th, 2006 09:59 AM |
