Old October 30th, 2007   #1 (permalink)
Name: Dean Al-hilali
Wales
Default Autocad 3d to 2d
hey guys,
this is for those that use autocad....
can you take drafts directly from a 3d model? i have experience with catia and this can be done very easily, is it that same for autocad?
cheers
deanomagino is offline
Old October 30th, 2007   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Autocad 3d to 2d
how do you mean, take 'drafts'?
STRAT is offline
Old October 30th, 2007   #3 (permalink)
Wales
take a 2d technical drawing from different parts of the 3d model
Old October 30th, 2007   #4 (permalink)
Name: Fotis Anastasiadis
Greece
Use the SOLPROF command
1. Go to layout, make a model view window, do not bother about scale
2. Set the view as you like eg. top, left ...
3. Type SOLPROF at the command line while you are INSIDE the model window
4. Select ALL objects, type yes or no to the other options...
5. Press Enter
6. Go to model , there is a flatten version of your 3d objects in a new layer...
You can also use the FLATTEN command but it destroys your 3d object
Have fun!
Fotman is offline
Old October 30th, 2007   #5 (permalink)
prodham's Avatar
if you are using 2007/2008 there are better tools than SOLPROF
try any of the three (depending on your needs)
1.) extract edges (XEDGES)
2.) flatshot (FLATSHOT)
3.) live section (SECTIONPLANE)
i've yet to really come to grips with the difference between 1.) and 2.) and live section can be a little fussy, but works well.
prodham is offline
Old October 30th, 2007   #6 (permalink)
Name: Misha Aronishidze
If you need real working drawings you should not use a 3d model. You have to draw 2d from scratch.
Mikho is offline
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
AutoCAD 2d to 3d Max Architectural Renders Odunayo General Discussions 4 June 27th, 2006 03:54 PM
Autocad & max yosa_b Finished Work 6 August 3rd, 2005 08:02 AM
Render in AutoCad P.R.S. Sivakumar General Discussions 13 September 11th, 2003 05:33 AM
At what point does AutoCAD bog down? Hazdaz AutoCAD/AutoCAD Architecture 14 April 15th, 2003 12:48 PM
