Name: Marc Bulebush |
I'm doing a sunlight shadow study for a city block. I got two questions:
1. Can you animate the sunlight system to go from 8am to 8 pm? When I go to the modify panel for the light, I don't see such option. 2. If I cannot animate the light, is there a way to change the time of day without having to create a new light everytime? Thanks all I'm using Viz 2008 |
Name: Conor Clancy |
Bully
The answer to both your questions is Yes. 1. to change or animate the settings of the sunlight system you must go to the motion panel. Here you can edit the times, dates etc. of the light. You can set keyframes at 8am, move the timeline on a few frames and set another keyframe for 8pm and the sunlight system will animate the light around your object in a semi accurate way. I say semi accurate because I don't know how accurate Autodesk's system is. 2. Yes, see above. |
| Animation #3 (Apartment in the four-storey house exterior and interiors) | PixelRendering | Finished Work | 7 | August 1st, 2007 06:03 AM |
| vray animation.. | shikodesign2000 | VRay Render | 3 | December 15th, 2006 06:12 AM |
| Animation in VRAY flickering? | charadesia | VRay Render | 2 | June 3rd, 2006 01:46 AM |
| Animation Help | steven martin | General Discussions | 0 | July 15th, 2005 12:51 AM |
| executive wing animation | crazy homeless guy | Work in Progress (WIP) | 30 | June 21st, 2004 02:20 PM |
