Name: darshit joshi |
I have to do interior animation in vray. And I want to show water flowing on glass.
Should I put video map on object..?? |
Name: Brian Smith |
particles are best but heavy to render. a map will work fine in most cases...such as in this short clip
www.3dats.com/downloads/waterfall.mov |
Name: Nils Norgren |
A technique that I have used successfully is to make a particle system, (pflow) that has the properties I want in a water wall, in an empty scene. Make the particles small spheres, put a simple light rig shining on the particles. Then I render out the particle system from a camera looking directly at the wall. I then bring the sequence into After effects and blur the sequence and re-render it out as a sequence to be texture mapped onto a water plane, with the reflections and IOR to make water.
Just a thought, -Nils |
| Help with "dirt on lens" effect in walk-through animation. | caes4r | VRay Render | 5 | November 1st, 2007 04:13 PM |
| C4D WATER SHADERS | STRAT | Cinema 4D | 28 | October 2nd, 2006 04:42 AM |
| Water park Animation | Bugga_Guy | Finished Work | 10 | March 13th, 2005 02:06 PM |
| water ripple effect | trey | Autodesk VIZ | 3 | July 31st, 2002 11:38 AM |
