Autodesk VIZ Autodesk VIZ
Old November 7th, 2007   #1 (permalink)
Ireland
Default Viz 2008 user paths and render farms
Am I losing my mind? Is there no way to update the user paths on my render farm in Viz 2008?
There's no 3dsviz.ini file which made adding map paths in previous versions quite easy. But in Viz 2008 the only way I can see to do it is use the portable license utility to activate each render farm pc seperatly and update the user paths. There has got to be an easiar way of doing it than this.
Any body got any ideas?
Please?
Anybody?
Hobo Monstrocity is offline
Old November 8th, 2007   #2 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
Default Re: Viz 2008 user paths and render farms
For MAX 9 and upwards (which includes VIZ2008) the configuration files are stored in sub-directories under your user profile - eg C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\ - check there for the 3dsviz.ini file.
Matt Clementson is offline
Old November 8th, 2007   #3 (permalink)
Chad Warner's Avatar
There's also another ini file names "installsettings.ini" that has a line "useUserProfile" if you set it to 0, it will install the same way as the older versions.
Chad Warner is offline
Old November 9th, 2007   #4 (permalink)
Ireland
Chad and Matt,
thanks for the help. I'm not at my PC now but I'll check the render farm in a few minutes
C
Old November 9th, 2007   #5 (permalink)
Ireland
Matt no joy with the INI file in the documents and seetings folder. I really don't know what to do. Any other ideas?
Old November 19th, 2007   #6 (permalink)
Ireland
Anybody?
Old November 19th, 2007   #7 (permalink)
Did you try a search for the 3dsviz.ini file?
Old November 23rd, 2007   #8 (permalink)
Ireland
yes I did, but to no avail.
Old November 23rd, 2007   #9 (permalink)
Do you have this file on your local workstation? If so - try copying it into the VIZ directory on the slaves.
Viz 2008 Vray Backburner Hobo Monstrocity Autodesk VIZ 2 September 24th, 2007 03:19 AM
Fileserver Migration - Paths issue Lupaz General Discussions 8 July 29th, 2007 08:20 AM
VRay Proxy's file paths.... JamesTaylor VRay Render 3 August 30th, 2006 04:12 AM
