Old November 7th, 2007   #1 (permalink)
Default Animating Escalator Stairs?
OK- So I'm trying to animate some escalator stairs for one of my work projects...
What I've done is created a ton of extra stairs and attached them together. Then I've added two slice modifiers at each end of the stairs - 1 to hide all stairs below the visible area and another to hide any stairs that would pass above the visible area.
The idea is to animate the position of the stairs, having them pass through the slice modifiers which basically hide any stairs that are not supposed to be in view, therefore having easily animated stairs.
The big problem is that when I set keys to move the stairs, the slice modifier moves with the stairs. How can I do this so the slice modifier doesn't move with the geometry!??
-OR-
Is there an easier way to do this?
This project has LOTS of escalators so I'm trying to keep it simple...
Thanks!
Ed
visualmusic.4 is offline
Old November 7th, 2007   #2 (permalink)
1eo
Default Re: Animating Escalator Stairs?
what program are you using.... have you tried particles?? you could make a particle that looks like a step and make it disappear once it reaches the top by controlling the timing of the particle.
As simple as that
1eo is offline
Old November 7th, 2007   #3 (permalink)
Thanks Leo-
I haven't considered the use of instanced particles. I'm using 3ds Max, so not that familiar with particles in Max but I'll give it a shot!
Old November 7th, 2007   #4 (permalink)
I just can't believe that it's impossible to animate the slice plane separately from the geometry. I guess this is a good example of how animating in Maya is much better for this kind of thing...
Old November 7th, 2007   #5 (permalink)
President/Founder
Jeff Mottle's Avatar
This should be what you are after: http://cebasserver.de/products/produ...8-35-788&PID=8
OR this:
http://www.turbosquid.com/FullPrevie....cfm/ID/274849
Jeff Mottle
CGarchitect.com
Jeff Mottle is offline
Old November 7th, 2007   #6 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
Assuming you're in MAX you could also animated one step moving to the postion of the next step and then simply add and out-of-range repeat to those keys for the relevant steps. I've done this before and it works well.
Matt Clementson is offline
Old November 9th, 2007   #7 (permalink)
Great. Thanks for all the options!
Animating low polygon people in C4d transformav Cinema 4D 19 March 14th, 2007 12:43 PM
Animating a Train with Elegance? Claudio Branch 3ds Max 1 November 8th, 2006 09:33 AM
animating camera frames hrvojezg00 3ds Max 3 June 4th, 2006 01:39 PM
Animating environment light! aflack 3ds Max 1 January 27th, 2006 05:48 AM
Animating revealing geometry Noise 3ds Max 2 July 13th, 2005 10:32 AM
