Autodesk VIZ Autodesk VIZ
Old May 16th, 2002   #1 (permalink)
HeDaCoM's Avatar
Spain Send a message via ICQ to HeDaCoM
wow.. very nice. heh... I don't have these problems... maybe you have to refine more the radiosity solution or try the regather option... but the real problem is that this model is a model for Lightscape or something... when you model for VIZ you have to model with solids... and don't have many different coplanar faces. that's the problem with the triangles created for the holes. try to model it with autocad in one 3D SOLID. Then import it with the file link manager.
Héctor D. Corcín
http://www.iruditek.com/hedaweb
HeDaCoM is offline
Old May 16th, 2002   #2 (permalink)
CHE
CHE's Avatar
United_States  Send a message via MSN to CHE
Hector,
The house was modeled in AutoCAD 2002. I used solids. I subtracted the doors and windows from the walls.
I was thinking.... maybe I should draw the face of the wall (with arcs and shapes) and then extrude the polyline, instead subtracting the shapes (solids) from the wall (solid). You know what I mean? I don't know. I'm using the 3DSOUT option to export the model and then I import it in VIZ. (I get better results that way). This is really frustrating. How do you model in CAD? How do you bring the model into VIZ?
[ May 16, 2002, 08:40 AM: Message edited by: CHE ]
CHE is offline
Old May 16th, 2002   #3 (permalink)
Name:
Cool
Che, did u subtract the door and windows together or individually? Subtract individually also gives better layer management.
Save as dwg. and import as dwg in Viz.
Hope that helps.
pgoh is offline
Old May 16th, 2002   #4 (permalink)
HeDaCoM's Avatar
yes that's the problem. forget the 3dsout command. import the DWG directly into VIZ. that doesn't generate those annoying coplanar triangles. substract solids as you do.
Héctor D. Corcín
HeDaCoM is offline
Old May 16th, 2002   #5 (permalink)
CHE
CHE's Avatar
Question
Does anyone know why this is happening? http://communities.msn.com/VisualRev...oto&PhotoID=14
CHE is offline
Old May 16th, 2002   #6 (permalink)
CHE
CHE's Avatar
Unhappy
Hector
I have imported that house as a DWG in VIZ and I have encountered problems with the smoothness along the edges of my arcs and circular shapes. They look polygonal. I have been playing with the importing options that VIZ has but I still ended up with polygonal shapes. That's why I used 3DSOUT. Could you share your settings with me? I'll give it a try again tonight. Thanks for the help.
CHE is offline
Old May 16th, 2002   #7 (permalink)
Name:
Try and subdivide the mesh, select the object(s)and apply the subdivision modifier. Make sure "show in viewport" option is on so you see what happens. Make the division quite small. Assuming you do radiosity, this will help anyway.
cyclops is offline
Old May 16th, 2002   #8 (permalink)
CHE
CHE's Avatar
Cool
Thanks Cyclops.
I think I figured it out. I played around with the radiosity settings and this is what I got:
http://communities.msn.com/VisualRev...oto&PhotoID=15
Make sure you check out my post under WIP ("Michoacan Project")as well. I have posted new renderings. Please leave some comments there. Thank y'all for the help. [img]Graemlin/biggrin2.gif[/img]
[ May 17, 2002, 07:52 AM: Message edited by: CHE ]
CHE is offline
Old May 17th, 2002   #9 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Hi che,
A bit late, but if you import from autocad, i hav e to tips for you:
- add an edit mesh modifier and go to sub-object/edges. select all edges, set edge treshold on 1 and click autoedge.
- go to sub-obj/polygons, select all polygons, set autosmooth treshold to 30 and click autosmooth
rgds
nisus
nisus is offline
Old July 29th, 2002   #10 (permalink)
matt_vinoir's Avatar
United Kingdom  Send a message via MSN to matt_vinoir
you could try altering the normals to unitfy in he mesh select. i cn't see the images but i think i'm geting the same problems using vectorworks. It does vary depending on how you fiddle with the radiosity buttons. but its really pissing me off. autodesk reseler if absolutley useless aswell, doesn't want to know!. Anyone don't buy from cadline in staines ever
matt_vinoir is offline
