Old November 15th, 2007   #1 (permalink)
United Kingdom  Send a message via Skype™ to Rendermedia
Default texturing large scale cityscapes
Hi All,
I have been given a Z model of a town which I intend to modify and map terrain textures, to,
around the centre of town are hundreds of small 3 bed terraced, semi, houses, the camera will not focus on this too much but I was wondering of any way I could procedurally / randomly assign different varying brick/roof textures,
Many thanks
Mark
Rendermedia is offline
Old November 15th, 2007   #2 (permalink)
kippu's Avatar
Default Re: texturing large scale cityscapes
i came across something www.metromodeler.com /// wont know if it helps you
www.renderviz.com
kippu is offline
Old November 15th, 2007   #3 (permalink)
Hi Thanks for the link
I have all the models i need, I was just thinking of an efficient way of giving hundreds of houses varying different textures via modifiers or a script
Cheers
Mark
Old November 15th, 2007   #4 (permalink)
chiquito's Avatar
Argentina
Theres a scrip Mat_id_dashboard
you select polys and it randomly assigns ids, use multi material. Tweak many variatians on photoshop. render by material layering?
chiquito is offline
Old November 15th, 2007   #5 (permalink)
Check out the MaterialByElement modifier.
sjmoir is offline
Old November 15th, 2007   #6 (permalink)
Hi thanks a lot
I will check those out, I think the script could be quite useful as I have hundreds of houses with varying brick faded etc,
I was thinking of something to do with the tile procedural map texture in max so that I can get true faded random images across the houses, the only thing I would need to watch is the mapping, although I am quite high up in the air.
I will give them all a try
Cheers
Mark
Large Scale Images nisus 3ds Max 10 April 4th, 2007 06:04 PM
Visualization Insider - Creating Vegetation on a Large Scale Part 2 of 2 Jeff Mottle CGA News 4 November 21st, 2006 07:11 AM
Visualization Insider - Creating Vegetation on a Large Scale Part 1 of 2 Jeff Mottle CGA News 8 November 8th, 2006 10:57 PM
importing large scale autocad drawing dvmorris Autodesk VIZ 7 May 31st, 2006 06:55 AM
How to make believable Large scale Scene materials in Max? Dave Bond 3ds Max 3 September 22nd, 2005 02:47 PM
