Name: lokesh bm |
When I was going through a tutorial, there was a file which gives a "POP UP NOTE" about the method of doing and the tips.
Is this a script which runs at opening time. My question is how to do this. I tried to overwrite this through "file properties" it did'nt work. I am having max 9.0 can anybody tell me what's this !!!!!!!!!! |
It's built into MAX but not usually enabled in the UI. You need to customise your Menus and add 'Add a Pop-up Note' to the menu then you can access it.
One word of warning - I have in the past had issues with files saved with notes and network rendering - not sure if this issue was resolved in later MAX versions but just letting you know so that you're aware that there could be an issue. |
OK - here it is in steps;
1) Start MAX 2) Choose Customize -> Customize User Interface... from the menu 3) Go to the Menus tab 4) In the box on the right expand the File menu so you can see all the entries 5) From the Actions box on the left scroll down till you find 'Add a Pop-up Note' 6) Drag 'Add a Pop-up Note' onto the window on the right, position it where you want it on your menu. (I put it under Summary Info) 7) Close the customise box and you should now have a new menu option on your File menu. 8) Whenever you want to add a pop-up note choose this menu option and you're away. |
| Max Script..... | hmahesha | Scripts | 3 | March 9th, 2007 06:11 AM |
| MAX Script for replacing geometry in an imported DWG file? | jonssonhenrik | Scripts | 1 | June 26th, 2006 07:32 AM |
| Rendering large images - what's the script? | Rick Eloy | 3ds Max | 13 | May 31st, 2006 12:46 AM |
| script: Random material ID | quizzy | Scripts | 2 | April 22nd, 2006 03:04 AM |
| 3dsmax Layer State Script | Jeff Mottle | Scripts | 0 | September 22nd, 2004 12:11 AM |
