Name: Jamie Hopwood |
does anybody know of where a good 3dmax golf course tutorial is? or what the best way to create a golf course would be? eg bunkers and having the fairway lay across the terrain
cheers |
Name: julian boswell |
here's one way I have done a golf course:
start with a plane - Use the FFD box modifier to start pushing and pulling your terrain (don't use the Max terrain modifier with topo lines). In poly edit mode you can paint-in smaller features if you need to. Use shape merge using a closed spline over the terrain for your greens. You probably want to do that first. If you have to model something pretty accurate then build the terrain with topo information and use the terrain modifier - then drape a plane over the model and use the cloth modifier so make a smooth surface, then delete the terrain under it. |
| tutorial exposure problem | Geoffc | VRay Render | 2 | May 18th, 2006 11:33 AM |
| Lightscape to Lightwave v8 tutorial | exception | Lightscape | 7 | February 7th, 2005 07:47 PM |
| Barcelona Ottoman Tutorial | voltaire_ira | 2D/3D Tutorials | 3 | November 24th, 2004 07:56 PM |
| Npower Power Booleans Architectural Tutorial | Jeff Mottle | Industry News | 4 | November 6th, 2004 09:35 AM |
| 3dsmax Hourglass tutorial | <--rYaN--> | 3ds Max | 0 | April 7th, 2004 12:35 PM |
