Hi all
Why is it when importing DWG files, you get duplicated faces when you go into the sub object mode, once they are converted from linked Geometry to editable meshes, Kind Regards Mark Last edited by Rendermedia; November 20th, 2007 at 06:55 AM. Reason: ommitted detail |
Name: ron lloyd |
I'm "guessing" its because many rendering engines only display and light the "normal" side of a triangle. The importer needs to duplicate the face with another identical face but with an opposite normal so you will be able to see the back side of it (or not have to worry about which side is normal).
| MAX Script for replacing geometry in an imported DWG file? | jonssonhenrik | Scripts | 1 | June 26th, 2006 07:32 AM |
| flatten imported dwg | notamondayfan | 3ds Max | 5 | May 17th, 2006 01:12 AM |
| open path same as dwg path | RAYMOND | AutoCAD/AutoCAD Architecture | 1 | April 17th, 2006 03:50 PM |
| Diffuse maps on imported DWG files. | Cirrus | 3ds Max | 2 | December 18th, 2005 11:09 AM |
| Max6: How to get rid of the prefix 'Layer:' in importing dwg | HarryG | 3ds Max | 0 | November 30th, 2003 08:16 PM |
