Hi all,
I have approx 400 simple cubic buildings that I need to box map up, I seem to remember a script somewhere that allows you to select multiple objects and it applies a UVW box map at each objects centre point, Does anyone know what this is called, I have look on maxplugins.de, scriptspot seems to be a bit laggy at the moment. Kind Regards Mark Last edited by Rendermedia; November 20th, 2007 at 07:56 AM. Reason: Typo error |
Hi there,
I do remember something like that but it was a few years ago, probably for an old version of max. I think you can do it without plugin. Just apply UVW to one and set it how you want. Then right click and copy the UVW in the modifier stack. Then select all the other objects and apply a UVW (or any modifier i think) then right click PASTE INSTANCED on top of that one. You can then delete the first modifier, you only added it because you can't paste on to nothing. Hope this makes sense, think it will work, hope it helps |
started to write one off the top of my head lol, but you can get http://scriptspot.com/3ds-max/multiuvw instead :P or just search scriptspot for mutliple uvw if that script doesn't do quite what you were looking for.
Dave. TD / EwingCole DMG |
Hi
The main problem that I have is that the pivot on each objects local axis is not in the correct position to the objects normals, so if I use this script, the UVW map is wrong on all objects, I have worked around it by using material by element modifier (plain flat colour) and then individually mapping faces manually on those objects that are bigger. Kind Regards Mark |
| Difference between Max and Maya | whale | General Discussions | 16 | July 20th, 2007 02:08 PM |
| uvw mapping and unwwap uvw maooing | al_farooq | 3ds Max | 1 | March 15th, 2007 11:16 PM |
| MAJOR bug in brick material or UVW mapping????? | quizzy | 3ds Max | 4 | June 8th, 2005 02:14 PM |
| Modeling: Selecting single objects on one layer coming from AutoCAD into MAX | Jet | 3ds Max | 4 | November 5th, 2003 08:08 AM |
| Max 3.1 Brick Color Mapping | camby | 3ds Max | 2 | August 4th, 2003 02:22 AM |
