Old November 20th, 2007   #1 (permalink)
Default HELP -- How would you model this?
So I am working on lobby for a client and i need to model this curved mosaic tile inset into the lobby floor. I am going to model this as a seperate object obvioulsy, but I am having a little difficulty figuring out how to model this so that my texture map will follow the design.
I have uploaded some pics of the overall shape of the curved tiles, and a closer pic to show how the texture map has to flow with the design.
Any ideas on how to pull this off?
Thanks in advance.
VCRUPI is offline
Old November 20th, 2007   #2 (permalink)
Default Re: HELP -- How would you model this?
i'd be lofting it if you need the tiles to follow the path of the curve
JamesTaylor is offline
Old November 20th, 2007   #3 (permalink)
Well I thought about using a loft or sweep modifier... but how would I apply the UVW map to properly show the texture curving with the shape?
I guess this is more of a question about the UVW mapping more than the modelling.
VCRUPI is offline
Old November 20th, 2007   #4 (permalink)
It tried out what you suggested & it worked. I didn't know that when using the sweep or loft modifier that 3ds max would take into account the mapping of the object.
Thanks.
VCRUPI is offline
Old November 20th, 2007   #5 (permalink)
UVunwrap - save out to photoshop and texture it in there. When you import it use the vray diplacement modifier to bump up the tiles.
ipxstudios is offline
Old November 20th, 2007   #6 (permalink)
louis.cho's Avatar
Name: Louis Choinière
yup, it's the way i would use too. You could also make a plane in editable poly follow this shape and put a UVW Map with the facing option. align it with the floor and I don't think you will notice any separation.
______________________
Louis Choiniere
www.espaceparallele.com
louis.cho is offline
Old November 20th, 2007   #7 (permalink)
jvlive's Avatar
Name: julius hontarigo
Philippines
Or the classic tutorial from the resources page:
http://www.cgarchitect.com/resources...tutorial11.asp
you didnt mention what version you're using (sorry, I'm kinda stuck in 7.5 for a long while)
the early bird gets the worm, but hey, the late worm missed the bird.
jvlive is offline
What is the best way in making 3d model in Architecture? juan General Discussions 41 June 11th, 2008 02:15 PM
Change a editable spine into a model with skin Michael Earley 3ds Max 1 October 23rd, 2007 08:27 AM
$ / hour Jago_0108 General Discussions 19 March 7th, 2007 04:21 PM
Help! Model Problems. swenson 3ds Max 0 February 23rd, 2005 09:17 PM
Organizing the model. Hector Lightwave 5 April 10th, 2003 12:33 AM
