Old November 21st, 2007   #1 (permalink)
Kuwait  Send a message via MSN to murtazasimari
Default .3ds file
Recently i bought one CD with 3D max Blocks the file is having .3ds extension when i open this file on 3d max itz showing error i want to know that how i can open this file which programme i require...plz suggest me...
Thank you in advance
murtazasimari is offline
Old November 21st, 2007   #2 (permalink)
STRAT's Avatar
Wales
Default Re: .3ds file
your instruction manual tells you about opening .3DS files in Max
STRAT is offline
Old November 21st, 2007   #3 (permalink)
kippu's Avatar
File >>> import
www.renderviz.com
kippu is offline
Old November 23rd, 2007   #4 (permalink)
3dSol's Avatar
Bolivia
Hi,
do not use the open command
use the IMPORT command
good luck!
3dSol is offline
Importing a .3ds file into Sketchup ruds SketchUp 1 November 9th, 2007 03:47 AM
FileLink in Max 9 crazy homeless guy 3ds Max 12 April 1st, 2007 07:24 PM
Help with importing a .3ds file into cinema 4d guitarboy Cinema 4D 3 January 28th, 2007 03:29 PM
AUTOCAD dwg file convert to PDF file Chris Potts AutoCAD/AutoCAD Architecture 9 October 8th, 2004 01:42 AM
export archicad file to .3ds? angelo_anim Archicad 4 October 19th, 2003 01:36 AM
