Old November 22nd, 2007   #1 (permalink)
nazcaLine's Avatar
Peru
Default thumbnails not appearing
recently i installed max 2008, and before that i removed my max 8.
thing is that all my .max files don't show up in the max logo, and when i want to setup "always open this file with this program" max just doesn't appear in the list. so all my max files appear like an unknown file archive, i can't see thumbnails, it's frustrating. i have no problems opening and working with the files, though.
any idea about this? what can i do?
Eduardo
"I have nothing to do with the real world anymore. Please don't insist."
Eduardo Romero
nazcaLine is offline
Old November 22nd, 2007   #2 (permalink)
Rick Eloy's Avatar
Default Re: thumbnails not appearing
Click on a .max file's properties and assign 3ds max to open it. This "always use.." option often doesn't work.
Rick Eloy
Rick Eloy is offline
Old November 24th, 2007   #3 (permalink)
Name: Grant Salisbury
Eduardo
Here is the fix. Create a new text file and name it thumbnail.txt
Copy this text into the file.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.max\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
@="{9DBD2C50-62AD-11d0-B806-00C04FD706EC}"
Now rename the file thumbnail.reg. Right click on thumbnail.reg and select merge. Your thumbnails will now be displayed inside of windows explorer. If you have the same problem with Photoshop let me know. I could email you the fix for that as well.
Hope this helps you out.
grantsalisbury is offline
Old November 25th, 2007   #4 (permalink)
nazcaLine's Avatar
Peru
Rick:
the problem is that max doesn't appear in the program list. it's impossible that it isn't there! i'm working in max right now!
any other suggestion, idea? please...
grant:
thanks for your help, i'll try that as a last option. i think there has to be something more simple for this....
Eduardo
Eduardo Romero
Old November 25th, 2007   #5 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
Originally Posted by nazcaLine View Post
Rick:
If its not on the list then click the 'Browse' button and browse for your 3dsmax.exe file - that will associate the .max extension with the correct application.
Matt Clementson is offline
Old November 25th, 2007   #6 (permalink)
nazcaLine's Avatar
Peru
matt: i did exactly that. thing is that nothing happened, max just doesn't appear in the list. it's so annoying!!!
thanks for your help though
Eduardo
Eduardo Romero
Old November 26th, 2007   #7 (permalink)
Eduardo
You're saying that when you browse for 3dsmax.exe in your MAX installation directory its not there? That's just not possible. I'm not talking about the list of named programmes that opens up first - at the bottom of that window there is a Browse button that lets you pick any .exe on your system.
Old November 26th, 2007   #8 (permalink)
nazcaLine's Avatar
Peru
yes, i looked for with that browse button, and the 3dsmax.exe IS THERE, thing is that when i pick the .exe, and click "open", nothing happens. max just won't appear in the list. strange, huh?
another case for the X-files...better say, maX-files...
Eduardo
Eduardo Romero
Old November 26th, 2007   #9 (permalink)
I assure you it is possible, and I'm with NazcaLine it drives me nuts. Not nuts enough to have blind faith in the operability of Windows mind you, but it does hamper the work flow.
znotlin is offline
Old November 27th, 2007   #10 (permalink)
nazcaLine's Avatar
Peru
yup, something happens here...as i say, the max.exe file is there, it's just that when selected, it doesn't appear in the list. it's so annoying, i can't see the thumbnails in the explorer!!!
Eduardo
Eduardo Romero
can't see thumbnails with autocad 2007 3dsmaxed AutoCAD/AutoCAD Architecture 4 October 4th, 2007 02:18 AM
Far objects keep appearing and disappearing in animation pradipta VRay Render 2 September 19th, 2006 12:17 AM
Vertex points appearing tiny FlytE Autodesk VIZ 2 September 13th, 2006 06:25 AM
Thumbnails Dibbers General Discussions 3 May 30th, 2004 12:39 AM
background appearing in glass gus_webb Autodesk VIZ 1 April 9th, 2004 12:32 PM
