Hello!
I have this exterior project coming soon, and decided to give MW a shot. I have lots of windows and balcony doors in the scene, so I was wondering if the method I used so far for glass modeling, also applies to MW. What I have are 2 meshes, one facing out and one towards the room. Will this work, or I have to do something other to get nice looking glass in MW? Thanx ![]()
Beeeee! |
Name: Devin Johnston |
Your glass has to have thickness it can't be just a plane. You say your using meshes I sounds like you have two planes in which case it might work, Maxwell really need for there to be a thickness between the front and back of the glass in order to simulate glass properly.
Name: todd storch |
Maxwell doesn't mind overlapping geometry. I don't know if using 2 planes will give you desireable results, best way to tell as Maxer stated above is to just try it. Render one image with the glass as 2 planes and then another with glass as one plane with thickness... compare which one looks better as well as how long they each took.
As for a glass material the built in mxm wizard can create glass and/or AGS. If you have a specific problem with the glass mat let me know. |
| glass material: comparing Max vs VRay | smr_VIZ | VRay Render | 0 | November 26th, 2007 09:12 AM |
| LWF guidance needed. | Tommy L | VRay Render | 21 | August 20th, 2007 09:18 AM |
| Fritted Glass in Modo and generally | Hector | Modo | 2 | May 11th, 2007 05:41 PM |
| glass reflections | jccloutier | VRay Render | 10 | July 25th, 2006 08:20 AM |
| vray glass | Timothy Saunders | VRay Render | 10 | March 20th, 2006 02:24 PM |
