Old December 11th, 2007   #1 (permalink)
Default beginner's problems
There are some things about maxwell that don't seem to click with me.
1. Where are Maxwell lights with Maxwell shadows, I use 3d studio max.
I don't understand how you are supposed to setup lights.
2. Why everytime you hit Render, a Maxwell render opens, it irritates me a little, can it be more integrated into 3dsmax, I don't want to close window everytime I test.
3. Are there any good tutorials for 3d studio Max?
thanks.
Kris.
d7man2000 is offline
Old December 11th, 2007   #2 (permalink)
Maxer's Avatar
Default Re: beginner's problems
thanks.
Kris.
1. Maxwell lights are created using an emitter material; basically any object in Maxwell can be a light if you apply this material to it. Try to use the most basic geometry with the fewest faces you can when making emitters because the more complex you make it the more noise it will generate.
2. Maxwell is a stand alone program that is accessed by 3D Studio through the plug-in. This is the only way for Maxwell to render you will have to get used to it.
3. Are you looking for Max tutorials or Maxwell?
“There is no spoon”
Maxer is offline
Old December 11th, 2007   #3 (permalink)
thanks for reply,
I meant tutorials for Maxwell with 3d studio max.
Old December 12th, 2007   #4 (permalink)
Maxer's Avatar
Check the Maxwell fourm, there are some good ones there.
“There is no spoon”
Maxer is offline
problems using dome lighting jafs00 VRay Render 2 June 21st, 2007 05:56 PM
Big Backburner Problems Maxer 3ds Max 13 May 18th, 2007 11:06 AM
Viz 4 Crashing problems Showcard Autodesk VIZ 4 February 15th, 2007 03:20 PM
Memory Problems: 2GB limit ??? nisus General Discussions 2 November 9th, 2004 10:51 AM
A recipe to deal with problems downloading/installing 7.0 content. Richard McCarthy Autodesk Revit 1 October 27th, 2004 05:09 PM
