Old December 29th, 2007   #1 (permalink)
Default Network Rendering Problems - Maxwell Render
I am having problems using Cinemaxwell plugin.
I have two computers linked via crossover cable. My desktop is the 'host' computer where the MXS is saved. The laptop is being used as a node. All the textures being used are saved on the 'host' computer in shared folders.
I can render an image WITHOUT textures without any problems. As soon as I try to render an image using bitmapped textures it fails, the node computer says: cannot find....(material name). It seems to struggle finding the textures on the main computer? The error message indicates which folder is it looking in for the textures, and it is looking in the right place! I have also double checked that the folder and the material is shared.
The network seems to be set up correctly as I can view the files/folders on each computer so I can't understand what's going wrong.... please help before I go mad....
For the love of god please help!!!!!!!!!!!!!!!
simbeanie is offline
Old December 29th, 2007   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Network Rendering Problems - Maxwell Render
i deleted your other threads, only one post will do please
STRAT is offline
Old January 3rd, 2008   #3 (permalink)
markus groeteke's Avatar
Germany
did you select this shared folder containing the textures with the 'default path' for bitmaps in the 'add job' render options? this usually resolves any path problems.
cheers
markus
3dworks visual computing - berlin, germany
www.3dworks.com
click here for more images
markus groeteke is offline
Vray distributive Network Rendering Errors Generate VRay Render 2 November 19th, 2007 12:39 PM
Request: Network Rendering How To For Beginners thickly Hardware and Technical Discusions 1 November 1st, 2006 11:00 AM
Vray rc3 & max9 network rendering prob philip kelly VRay Render 4 October 31st, 2006 10:09 AM
Network Rendering & Render Farm Information Arnel General Discussions 0 October 26th, 2003 02:25 PM
network rendering problems??? miguelafi Hardware and Technical Discusions 5 April 2nd, 2003 05:24 AM
