Autodesk VIZ Autodesk VIZ
Old January 3rd, 2008   #1 (permalink)
Default Architectural Materials
Hello,
I've just completed this rendering and I've noticed some jagged edges on the reflections. I'm using Radiosity and the Scanline renderer. My materials are architectural materials and I'm using the presets. I'm trying to get the floor to look like a high-gloss white epoxy so I'm setting the diffuse color to white and using the gloss paint preset. The reflections have a bit of a jagged edge to them though. Is there a better way to create this material? Also, I would like the reflections to be slightly wavy to appear more realistic for an imperfect troweled epoxy floor. I was thinking of trying a bump map...any suggestions? Thanks!
Also, I would love any other critiques of this rendering.
jtseaman is offline
Old January 3rd, 2008   #2 (permalink)
prodham's Avatar
Default Re: Architectural Materials
nice image for scanline...
let me have a think about the material issue and i'll get back to you (i'm not able to work in VIZ/MAX right now).
i don't think a bump map is the answer for reflections - isn't there a reflection map slot for architectural materials ?
or maybe it is just a resolution issue, or anti-aliasing settings ? i've found most architectural materials to be pretty good and not much need for tweaking.
on another point - what is up with the bench ? it looks like a hollow batt insulation hatch pattern (no offence)
prodham is offline
Old January 3rd, 2008   #3 (permalink)
Smile Re: Architectural Materials
Thanks for checking into it. I've attached several pictures of the effect I'm trying to achieve with the floor. I love the reflection of the elevator on the third epoxy floor image. The wavy part on the bottom looks great and shows more realism since epoxy on concrete is not perfectly level.
I rendered the image at 2250x3000 so I don't think it's a resolution issue. I didn't think it would be an anti-aliasing issue either since the other angled lines are very straight. I've attached a close-up of the rendering so you can see the problem better.
No offense taken with respect to the bench...your description of it made me laugh. Check out www.amplesample.net it was a design using carpet samples for a competition I entered.
Thanks again!
jtseaman is offline
Old January 26th, 2008   #4 (permalink)
At the material, I turned on local supersampler and left it at the default and the problem cleared right up.
Peter M. Gruhn is offline
vray tip for those using architectural materials crazy homeless guy VRay Render 17 September 9th, 2006 12:55 AM
Architectural Materials emortal 3ds Max 8 May 16th, 2006 01:43 AM
architectural materials ARCHY VRay Render 1 February 6th, 2006 01:54 AM
M7: architectural materials nisus 3ds Max 7 March 22nd, 2005 01:57 AM
Architectural materials in Viz 2005 Koskinen Autodesk VIZ 1 June 24th, 2004 12:09 AM
