Autodesk VIZ Autodesk VIZ
Old January 7th, 2008   #1 (permalink)
piotrgreg's Avatar
Name: Piotr Grzegorczyk
Poland  Send a message via Skype™ to piotrgreg
Default problem with importing *dwg curved objects
Hi everyone
my problem is quite simle ( as the solution, I suppose):
I prepare models in Acad and link 'em with viz
on the example attached You may see the circle-shaped head of the bed that becomes the polygon in viz
what shall I do to avoid polygons and smoothen this?
Piotr
piotrgreg is offline
Old January 7th, 2008   #2 (permalink)
piotrgreg's Avatar
Default Re: problem with importing *dwg curved objects
OK, I ve red some previous posts in this matter - thanks cdarchitect forum!
the solution is: to reduce "3d deviation for 3d solids" in the file-link initial window
AND IT WORKS
P
problem importing Arch Desktop model to max using vray jeff_3447 General Discussions 7 October 20th, 2007 08:11 AM
importing curved objects from AutoCAD wicho Autodesk VIZ 4 May 16th, 2007 03:27 PM
Problem importing dwgs / line creation le perdusier 3ds Max 4 December 9th, 2005 10:21 AM
problem with rotating objects kris 3ds Max 4 September 22nd, 2005 11:09 AM
I have a problem with moving objects t.fzr 3ds Max 2 June 2nd, 2005 12:46 PM
