Autodesk VIZ Autodesk VIZ
Old February 13th, 2008   #1 (permalink)
Default sketch, toon, hidden line....
Not sure about the proper name, but how can I achieve that type of rendering with VIZ ?
I just want the easiest one, everything's white, with black lines in the edges....thats it.
I couldn't find info for this, except some mental ray contour shader tut on 3dtotal. that quite worked, but it didnt actually rendered all the edges, tried rendering at bigger resolutions, and you get more details, but still there are lots of edges not showing up.
salf is offline
Old February 13th, 2008   #2 (permalink)
Ray
Ray's Avatar
Default Re: sketch, toon, hidden line....
VRay Toon is in the Environment/Atmosphere rollout.
Sorry, I didn't see that VRay wasn't mentioned in your post.
(Too many threads in my head.)
Ray is offline
Old February 13th, 2008   #3 (permalink)
lol.....
thats ok.
Here in the office we only have VIZ (which comes with MR)
salf is offline
Old February 13th, 2008   #4 (permalink)
AJLynn's Avatar
Ink&Paint material?
AJLynn is offline
Old February 13th, 2008   #5 (permalink)
upshot's Avatar
I use the finaltoon plugin or toss it in sketchup... Both are very nice 'hand replicators'
Here is finaltoon... notice the depth que thickness on the lines as well (thicker in the foreground thinner in the background):
I like to use finaltoon even in material correct renderings to 'soften' them.. There is something about a little hand faking that really relaxes a client (if you know what I mean). It takes them out of the 'is that a real photo' mindset...
Detail (the sharp black lines on the glass (right) were also done with a finaltoon material):
upshot is offline
Old February 18th, 2008   #6 (permalink)
thanks for the replies....but...
VIZ 2007 doesnt have ink and paint, atleast I havent found it
I can't use a plugin, gotta be VIZ tools only...so I guess that makes it harder, if not imposible...hehe
salf is offline
Old February 18th, 2008   #7 (permalink)
Tommy L's Avatar
The "ink 'n' paint" is a MR shader I beleive. You will have to mess around with the settings a bit and maybe render in passes to get the look you desire, but the render time will be very fast when you get the settings nailed.
Tommy L is offline
Sketch and toon ZFact Cinema 4D 3 March 18th, 2007 10:58 AM
hidden-line sketch & toon export to illustrator edub Cinema 4D 12 March 7th, 2007 06:26 AM
Sketch and toon for 3D max? justintime1 3ds Max 7 February 13th, 2007 08:58 AM
toon rendering or hidden line? illyrianeye Autodesk VIZ 3 September 26th, 2006 06:20 AM
