Name: Amir Zobel |
Hello,
I'm using the Maxwell Render Plugin for Solidworks, pretty new with it and trying my best learning through tutorials. Anyway, I can't find a solution to that problem I have: Why does the mapping of the texture changes (as you can see in the attached picture) between the flat surface and the rounded surface? The Two surfaces belong to the same component which the material was applied to. How can I change it? I would deeply appreciate your help. Thanks. |
Name: Amir Zobel |
Thanks for your reply.
I'm working with version 1.6.1, and as far as I know, that's the most up to date version. Anyway, I found out that it depends on the way I build the body originaly. It seems to me like a bug in the program. I Hope it will be solved in the next update. |
| Texture mapping | drvox | VRay Render | 7 | May 19th, 2007 05:45 AM |
| texture mapping missing!!! | mesht | Maxwell Render | 5 | August 3rd, 2006 10:44 AM |
| texture mapping | dnagi | 3ds Max | 5 | September 22nd, 2005 07:38 AM |
| Mesh To Texture Problem | isdito | Lightscape | 1 | June 8th, 2004 08:32 AM |
| Texture problem Mental Ray | Chucky | Maya | 2 | October 10th, 2003 07:51 PM |
