Old February 28th, 2008   #1 (permalink)
Default Displacement problem
Hi!
I need some help.
Attached you can see my displacement texture that I aplied to the ground plane. Material is very simple. I applied an displacement layer to the default material. You can see the settings I used.
Anyway, when I render the scene I get this monster....
Can some explain how to get an normal "displacment texture" look?
Thanx!
http://img231.imageshack.us/img231/6...tercopyxh8.jpg
http://img143.imageshack.us/img143/5276/etgcopyhf9.jpg
Beeeee!
del82 is offline
Old February 28th, 2008   #2 (permalink)
Default Re: Displacement problem
O.k. its solved, but I gotta tell you, I havent experienced slooooooower preview!
Horror!
Beeeee!
del82 is offline
Grass Displacement Problem IceAged Mental Ray 5 November 9th, 2006 08:37 AM
Vray displacement problem Dan J VRay Render 1 July 24th, 2005 02:25 AM
Displacement Problem rcase 3ds Max 2 July 1st, 2005 09:18 AM
Vray displacement problem Chad Warner VRay Render 2 December 3rd, 2004 11:07 PM
Displacement problem NeumannHomes General Discussions 5 September 17th, 2004 09:37 AM
