Old March 6th, 2008   #1 (permalink)
Default White Artifacts with the mental ray Arch&Design Material
Hi, sorry with my english, I`m from Sao Paulo in Brazil and I`m working in one project that have one problem with the mental ray Arch&Design Material. When I check on the option Fast Interpolate in the reflection group in the material appear white squares.
How I solve this problem?
hasin is offline
Old March 6th, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: White Artifacts with the mental ray Arch&Design Material
Are they reflections of bright spots that got interpolated down to big squares? Have you tried futzing with the interpolate settings?
AJLynn is offline
Old March 6th, 2008   #3 (permalink)
Hi Andrew,
they're not reflections of bright spots because the position of the mr Sun. I try change the value of the glossy samples, the Interpolation grid density and the Neighboring points to look up, but this values simply change the form and the size of the squares, and if I change the position of the camera change the position and the quantity of this white squares, or simply this squares dissapear.
I'm using the Logarithmic Exposure Control in max 9. I don't know if it changes anything.
hasin is offline
Old March 7th, 2008   #4 (permalink)
Ireland
I read somewhere that there can be a problem with the brush metal standard material in A+D. Try change to a different material and add a bump map
Let me know how you get on?
Tommy Burns is offline
Old March 7th, 2008   #5 (permalink)
Hi Tommy,
I Will try, but the problem is when i use intepolation for materials how Wood...
hasin is offline
Old March 8th, 2008   #6 (permalink)
I think it is bcoz of Anitialising.
mohitjersy is offline
Old March 9th, 2008   #7 (permalink)
ramy's Avatar
Try increasing your glossy samples in the reflection for the materials that have the artifacts. Increasing them to something like 256 will be fine as long as you are using fast-interpolate. This may give you a better result.
my website | my 3ds max tips | my portfolio
ramy is offline
mental ray glass material smr_VIZ Autodesk VIZ 2 October 7th, 2007 08:36 PM
mental ray: glass material smr_VIZ Mental Ray 1 September 17th, 2007 04:04 PM
Mental Ray, final gather and bucket artifacts AJLynn 3ds Max 10 June 20th, 2005 08:03 AM
Mental Ray shadow artifacts -help! rad_thundercat 3ds Max 6 January 26th, 2005 09:27 AM
