Name: Phillip Wharton |
The attached image is a revised image I am working on. I have moved the lights in the ceiling and when I render a new solution I get a ghost of the where the lights use to be. This Image is done in Viz 2008 and rendered with Mental render. Global Illumination is on and Final Gather is on and set to Low, the finish on the ceiling is an architectural material set to "paint semi-gloss"'Can anybody tell me whats going on?
Name: Justin Hunt |
If you move lights and or objects and dont delete and recreate the FG and photon solotions, then you will get artifacting. This is due to the lack of fg/p samples or the shadowed samples from the old solution.
There are certain situations where you can get away without deleting/recreating the solution but its not a good idea jhv |
I thought it did a new solution when I hit the render button. its goes through the Final gather pass before it gives me a render. Am i missing something? What do I need to do to delete the old FG?
Name: Thomas Burns |
Press the X beside where it shows you where the map is been saved and then make another one with a different name (just in case) and don't tick the read only box
Ok, I feel Dumb, I had unchecked the read only button and figured it would rewrite the file if I left the read/write button checked. Anyway any commits or suggestions are welcomed.
Just start afresh with the FG file and create a file with a copletely different name to be sure your making a new one or just render it without saving any files to see if its ok
| Light direction of image in 3ds max- missing attachment here | nilariver@gmail.com | 3ds Max | 4 | February 1st, 2008 11:40 PM |
| Rendering Problems/ huge image | dnagi | General Discussions | 6 | February 8th, 2007 03:33 PM |
| Further analysis of jpeg image compression... | crazy homeless guy | General Discussions | 3 | March 20th, 2005 12:21 AM |
| how. ? | anvaraziz | General Discussions | 9 | December 4th, 2004 11:35 AM |
| Newbie Question: Is this image difficult to create? | JAVB | Autodesk VIZ | 3 | November 16th, 2003 02:01 AM |
