Old March 18th, 2008   #1 (permalink)
Default First ever 'nearly finished work'
Guys this is the first piece of work that i have posted that has ever been anywhere near completion.
Thanks to Jeff Patton for the building shell
Some models taken from Evermotion
Please comment and criticise this render as much as you can guys, i really want to improve.
And before you comment on the curtains i agree that they look wrong and horrible and i am currently trying to fix them as we speak
Other than that, please help me improve
Cheers guys
Edit: The render has been done in Mental Ray 3.6, with MRsun MRsky, MRphysicalsky, p/graphic exposure and FG. No post work has been done
The image is straight from Max but, not too sure why it looks kind of fuzzy, looks fine on my screen, think its the compression from the original render so that i could post it on here.
daveb867 is offline
Old March 18th, 2008   #2 (permalink)
Default Re: First ever 'nearly finished work'
43 views and no comments??
surely there are loads of criticisms . . .
any comments are welcome. i really wanna get to work on my showreel so i need you guys to help me make it as good as possible
daveb867 is offline
Old March 18th, 2008   #3 (permalink)
Koper's Avatar
Name: AdriaaN van Jaarsveld
South Africa
I'm a vray guy so i'll just point out one thing. The bricks on the wall look way to big, as with the tiles on the floor. If you scale them down more detail should come through.
the lighting looks real!
coool
_____________________
AvJ
www.nationalgraphix.com
Koper is offline
Old March 18th, 2008   #4 (permalink)
thanks koper
the lighting was my main concentration if i'm honest with you so that compliment goes a long way
as far as the brick and tiles go, i agree with you, i shall get them scaled down.
any tips on making my curtains better
daveb867 is offline
Old March 19th, 2008   #5 (permalink)
rnx
Hi,
I think you could raise your settings. There are those splotches on the curtains that indicate low settings. The Gi settings i mean. Plus of course the antialias settings also could be raised. That should churn out a really great pic.
All the best.
rnx.
rnx is offline
Old March 19th, 2008   #6 (permalink)
muchhal.sandeep@gmail.com's Avatar
India  Send a message via Yahoo to muchhal.sandeep@gmail.com
Hi Dave,
The image is quiet ok as per me just a few things to add.
also use the photons for light along with FG i.e. use FG and GI can give it a try to see the difference.
the curtain and its material as u said.
if I would have been at ur place I would have opted for some reflective floor. (Truly personal)
even ur edges are not coming out sharply (INCREASE AA 1 min :16 max as a minimum value in any case)
And I am not sure if thr is some glass in the openings in front if it is so it doesnt seems to be and if thr is NO glass then PERFECT.
Hope it works.
Regards:
Sandeep (got a new machine)
(Intel 5299-ws chassis, 2 X e-5420 , 500-XVN MB, 4 GB FBECC Ram ) This is what sandeep is all about
muchhal.sandeep@gmail.com is offline
Old March 19th, 2008   #7 (permalink)
thanks for the comments guys
i'm currently rendering a 6000x6000 pixel render, i have included GI in the calculation
i have increased my sampling settings and the fg settings
GI is optimized for fg and i have altered the RGBA values for spatial contrast
i like the floor as it is its meant to be a really diffuse tile a bit like limestone would be
and at current there is no glass in the windows, it was having a major effect on the sky portals, but i also like the kind of 'open-air' look that having no glass gives off. suits the environement
will keep you guys posted, any other crits then let me know
daveb867 is offline
Old March 20th, 2008   #8 (permalink)
mattclinch's Avatar
England  Send a message via MSN to mattclinch
looking forward to seeing the update Dave.
Matt Clinch
Arch Viz Artist @ Hayes Davidson
http://www.hayesdavidson.com
mattclinch is offline
Old March 20th, 2008   #9 (permalink)
Kyle's Avatar
Thumbs up Re: First ever 'nearly finished work'
I would definately work on the glass in the windows.
Enough has been said about the curtains, but the pole they are attached to I would also look at as it seems as though it has been stuck on.
Other than that and what has already been said the ingredients are there for a really nice rendering I think.
Pleasure in the job puts perfection in the work.
Kyle is offline
Work vs. Prison alikashan Off Topic 13 April 3rd, 2008 03:46 PM
Submit your Architecture work jamiebyers General Discussions 5 June 24th, 2007 07:37 AM
I need work, Freelance or Permanent stheneboea Job Board 1 August 1st, 2006 04:02 AM
finished work doujay888 Finished Work 8 June 20th, 2006 03:45 AM
residence: first finished work celticdog Finished Work 1 February 1st, 2005 01:32 AM
