#1 (permalink) | |
Name: travis schmiesing |
When I read this, it sounds to me that if I change the geometry, the Photon Map is still valid. Which doesn't make a lot of sense when I try to think about it.
travis schmiesing |
Hi Travis,
I shall say that we both are feeling the same. as we change the geometry we shall recalculate the PMAP. the image size has got no problems once we save the photon map then we can render it at any required size need not recalculate.
Regards: Sandeep (got a new machine) (Intel 5299-ws chassis, 2 X e-5420 , 500-XVN MB, 4 GB FBECC Ram ) |
good to know. i was reading a another mental ray thread post today, and it referenced a different anomaly in the help files max mental ray help files.
travis schmiesing |
Name: Brian Bradley |
I assume that the help is making a distinction between possible
GI solutions that people may be using, such as Radiosity which is very much Geometry dependant. Chabnge the geometry and you will need to recalc your GI solution, which is not the case with photon mapping. (as a rule) regards Bri
#5 (permalink) | |
The majority of my GI experience is with Vray's irradiance map, so I am processing this in relation to those terms. Using irradiance passes, the map is representation of the 3d geometry in the scene. If I change the geometry, then the map created by the irradiance solution does not have the proper geometry to align to, and becomes invalid. It is this thinking that is confusing me on photon mapping. I remember the tutorial saying something about the way it is calculated, but I can't remember exactly what it is now. I will look at it again in the morning, and try to decipher it.
travis schmiesing |
Nothing wrong with your understanding. If you make significant
alterations to your meshes in both VR and MR you would want to recalc your IR or PM. But with radiosity, if you change say the base number of segments in a box, then the solution becomes invalid because radiosity IS geometry dependant, the lighting info is stored at Mesh level! This is not so with photon or irradiance mapping. regards Bri
3Ds Max - Mental Ray - VRay - Brazil Training Modules www.mentalboutmax.co.uk The MBM Blog www.mentalboutmax.blogspot.com Vray Learning Resource www.vrayelite.com Last edited by Brian Bradley; March 21st, 2008 at 10:52 AM. |
#7 (permalink) | |
Whereas, or at least I believe that, irradiance maps pretty much become invalid as soon as the geometry is changed. I say this because if you open the Vray irradiance map file in the irradiance map viewer, you can see that that the surfaces are defined by how the light hits them. If you move a surface, the saved irradiance map does not reflect that move without recalculating. Or at least it does not reflect it with any deal of accuracy. Is there a viewer, or any way to look at a photon map to better understand how it works? …also, I assume that placing geometry close to a light source will affect how the photon map should behave, therefore making the saved map un-accurate because the distribution of light in the scene would have changed(?).
travis schmiesing |
after more research, i have to go with my initial inclination. ...when you change the geometry in the scene, you should recaculculate your photon map, because it is not accurate.
travis schmiesing |
Name: Mattias Henningsson-Jönsson |
Well, photons bounces against the geometry. If the geometry is moving you have to recalculate the photon maps (the same goes for fg maps) or the calculations will be incorrect. Otherwise the saved photons bounces against something not there and so on.
At the risk of sounding picky
precise to say the photons interact with the shaders assigned to the geometry. Without the photon info contained in there you would get notihng from your photons. Regards Bri
| Distributed rendering with Vray? Any clue to Maps diseapearing | jeandelessard | Hardware and Technical Discusions | 9 | October 31st, 2007 12:41 PM |
| FG/Photon Maps | louis.cho | Mental Ray | 2 | June 5th, 2007 04:01 PM |
| Panorama Missing Maps | lost in 3d world | Autodesk VIZ | 5 | November 17th, 2006 12:34 PM |
| Photo Recovery software for Mac Users | unsolicited | General Discussions | 0 | September 14th, 2006 05:24 AM |
| Missing Maps on Merge | mbr | 3ds Max | 2 | October 8th, 2004 05:54 AM |
