Name: Phillip Wharton |
This rendering is of a car I downloaded and imported from sketchup and added the A&D car paint materials on it to play with. The model has it problems but the strange thing is when I render it from the front I get the black triangles around the door. Same model from the side view and they disappear. Does anybody know what that is about?
I agree with Claudio - that's usually a sign of bad geometry. i.e. flipped normals or co-planar faces (2 faces in the same space).
Go to Poly/Face select mode and select the offending tri's and delete them. See if the weirdness goes away. |
I tried erasing them and that just left holes, I then tried flipping the normals and it still renders strange. Maybe I am doing something wrong? Also what’s with the big gap at the front of the door? on the model it looks flush with the surrounding mesh.
#6 (permalink) | |
Name: David Oakill |
In the end I've always found it easier to build from scratch in viz because until I fix/correct all the problems from importing I could have just built it cleaner to begin with. |
| How do YOU model your buildings? | vismagine | General Discussions | 8 | December 14th, 2007 02:50 PM |
| Merging files - BIG, HUGE problem, pls help | Koper | 3ds Max | 3 | February 19th, 2007 04:14 AM |
| File Link Problem... | demo38 | 3ds Max | 0 | April 13th, 2005 09:50 AM |
| Problem applying material to imported AutoCAD item | jtho | 3ds Max | 2 | April 5th, 2005 09:39 AM |
| Video Card problem? | Jeff's Friend | Hardware and Technical Discusions | 12 | September 11th, 2003 04:33 AM |
