Name: travis schmiesing |
I have a question.
When I use distributed with Vray, the machine's IP or name that the bucket is assigned to appears in the bucket. Which makes it easy to identify trouble machines, and remove them if need be from the distributed render. I am bucket rendering with Mental Ray, and receiving a lot of bad buckets, and it seems to be one machine that is giving them. Is there a way to identify which machine is producing these buckets? I am presuming the bad buckets are from memory issues. ts.
travis schmiesing |
Name: Joel Callahan |
http://discussion.autodesk.com/threa...hreadID=520311
They discuss it here, but they offer no solution. They seem to think it's a memory issue. I can only suggest finding a scene that gives you the bad buckets every time, then turn a machine off until you get rid of the buckets. Reinstall Max fresh. Re-render. If it still happens, check the hardware/memory. Good luck. |
Name: Justin Hunt |
If you open the message window, it will list which machine is doing which bucket. With a little deduction it is quite easy to determind which bucket belongs to which machine
jhv |
I don't know MR, but with FinalRender2 under C4D, you can assign a color to each machine's buckets. the buckets get a one-pixel border in that color. If you have dozens of colors it would be hard to tell one from the other, but with only a few its easy. You could at least group them, the reds being one group, various blues another. See if there's something like that you can do.
Oh, another bucket issue is time-outs. Check that out, too, and network issues. maybe the 'bad' machine is on a slow node? |
| 4 buckets or 8 buckets on Q6600 2.4Ghz | Lhanh29 | Hardware and Technical Discusions | 3 | January 18th, 2008 11:08 AM |
| DR Buckets | Geoffc | VRay Render | 3 | June 14th, 2007 03:36 PM |
| DR - My buckets look diff. then server buckets | MegaPixel | VRay Render | 6 | May 12th, 2006 09:09 AM |
| Mental Ray buckets | mskin | Other 3rd Party Renderers | 2 | November 21st, 2005 08:33 AM |
| Lost Buckets | Vince Paske | VRay Render | 1 | February 6th, 2005 10:16 AM |
