Name: Robert Jordan |
Hey all,
I was wondering if any of you could help figure out what is happening with this wall. First image shows it at render in viz. a section of the wall seems flat and has no texture, despite it being a corrugated metal wall. second shows how the wall is constructed in cad and how it's the same as the walls around it. Yet when rendered, a portion fo the section seems to appear flat, devoid of any texture. third images shows a closeup of the corrugated wall. appreciate any help. Also a note that says obsolete date pops up... anyone knows what's up? rob ![]() ![]() ![]() |
it was acutally a modeling problem in cad when you move certain objects in 3d mode in cad... it tends to not align.. because of the different axis. as it turned out, the wall in which the corrugated panel sits on somehow was overlapping it and causing the render to become flat bec. the corrugated is being overlapped with a flat wall.
thanks for the reply. |
Name: Raymond Salmon |
have you set you mapping to 2 sided
apparently the corrigation is modeled but may disappear from certain vp I have had this same problem with corrigated roofs. but 2 sided fixed it.. r aloha |
| gamma, net render of a batch render | Justin Hunt | 3ds Max | 0 | February 10th, 2008 04:35 PM |
| Network Render File Saving Problem | Tiny Piney | 3ds Max | 0 | August 8th, 2005 08:35 AM |
| Final Render Problems | Maxer | finalRender | 5 | November 10th, 2004 08:30 AM |
| problem render to AVI | HAIDORY | 3ds Max | 2 | November 1st, 2004 04:08 AM |
| region net render in viz4 | quizzy | Autodesk VIZ | 15 | December 24th, 2002 12:42 PM |
