Autodesk VIZ Autodesk VIZ
Old April 8th, 2008   #1 (permalink)
Default Viz problem
I've had some major problems with Viz lately. I would open an older Viz file (Viz2006) and start rendering it in Viz 2008 and it would crash. So I check various other files and they would also crash. So I email a Viz Tech about the problem. They tell me I should collapse all my modifier stacks and then save it and open it up into the newer version...
That is the worse thing I want to do. How do you easily modify the objects? Everything is turned to mesh
It's like flattening a photoshop file with multiple layers and saving it so I can use it in a newer version. Or exploding the smart ADT objects in autocad. Whats everyone else think of this??
What I've done in the past is merge objects from another file into a newer file. This seems to help with some crashing. I've also noticed that any ADT object from AutoCad ADT would have errors. I used the STL error checker. Is this common that ADT objects are corrupted when imported into Viz?? Has anyone else run into these issues??
3ply is offline
Old April 9th, 2008   #2 (permalink)
Ireland
Default Re: Viz problem
Although I don't use ADT I did recently upgrade from Viz 2005 to 2008. The problems you describe are very familiar to me. The merging of the files into a fresh scene is also the only way I could get a lot of older files to work in 2008. Even then, when I need to make changes to older images, I just load them up into 2005. It's easier and much less frustrating.
Is it just me or does anybody else think Viz 2008 needs an enormous service pack up the a$$.
Hobo Monstrocity is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 2 Weeks Ago 04:38 PM
nurbs problem?? to_po 3ds Max 1 August 9th, 2007 01:06 PM
Radiosity Problem? tcupp Autodesk VIZ 6 April 24th, 2007 11:02 AM
File Link Problem... demo38 3ds Max 0 April 13th, 2005 09:50 AM
Video Card problem? Jeff's Friend Hardware and Technical Discusions 12 September 11th, 2003 04:33 AM
