Go Back   CGarchitect.com > ARCHITECTURAL VISUALIZATION COMPETITION > 2008 Architectural Visualization Competition > Challenge #1 - WIP
Challenge #1 - WIP This forum contains all of the WIP and submissions and critiques for Challenge #1
Old April 12th, 2008   #1 (permalink)
AJLynn's Avatar
Default Andrew Lynn - WIP
Well here goes. Not actually a building yet and none of the materials are right, so I guess that's why they call it WIP. I think this is close to the shot I'm going to use, and the parts that are there are a sort of conceptual parti.
AJLynn is offline
Old April 12th, 2008   #2 (permalink)
NgoJennifer's Avatar
Default Re: Andrew Lynn - WIP
hey! Im liking your concept. But I feel that the way the image is, the board is cutting the image in half. Can't wait to see more!
NgoJennifer is offline
Old April 13th, 2008   #3 (permalink)
Koper's Avatar
Name: AdriaaN van Jaarsveld
South Africa
intersting, but I somehow strugle with the comp. I think you need to rotate the camera more to the right so the lighthouse comes more into the frame. just a thought
coool
_____________________
AvJ
www.nationalgraphix.com
Koper is offline
Old April 13th, 2008   #4 (permalink)
AJLynn's Avatar
It's still conceptual. I like things this way, before they get all real and inevitably lose something in the process. I'm a big fan of the section-perspective in both design and representation, but since the deliverable here is a single perspective - and I think that's the most challenging aspect of this - I've decided to go with a design where the section-perspective is expressed in an elevation-perspective, and that's where I need to address the fundamentals. Program, progression, and the relationships that read on the horizontal and vertical axes - water/ground/sky, sea/land/tower. That's enough rambling about the concept for now, there's a lot on paper and I might get it caught up if I get some quality time with a scanner.
Conceptually, it still needs grounding, and half the program space. There's also a lot of work to do on the materials etc., including flipping the lights and darks in the curvy part. I'm taking a one-step-at-a-time approach to this, and will probably post too much for my own good It's my thread and I'll spam if I want to.
AJLynn is offline
Old April 14th, 2008   #5 (permalink)
Horhe's Avatar
There is definetaly a dialog going on between those two shapes. With every WIP towards the end its going to become more and more clear. This can turn out really well. Im wondering if they become more similar or differenicated towards the end. Go with the flow!
P.S. Ill help you spam your WIP
Horhe is offline
Old April 15th, 2008   #6 (permalink)
I think you have an advantage here to raise the camera up, but not too high
am34012 is offline
Old April 15th, 2008   #7 (permalink)
AJLynn's Avatar
Thanks. I've actually worked on the camera angle a bit, haven't had time to do much in the last couple of days but here's an update from after I changed the camera and moved things around a bit. Although I like the way the elevation perspective maintain the pure form of the diagram, I think my academic approach is going to lose out to the need for a more powerful composition, and I'll have to be content with having got this far with one of my qualification images being completely a theory piece.
AJLynn is offline
Old April 15th, 2008   #8 (permalink)
Philippines
Nice! Are those wavy roofs' gonna hold on well through strong winds? Anyway, I like the concept. It sure's gonna be awesome!
ronski_g23 is offline
Old April 16th, 2008   #9 (permalink)
AJLynn's Avatar
I was going to be concerned with things like winds, but when I saw that we've got one guy doing a 1km long phallic symbol and another doing an artificial archipelago the size of Puerto Rico, I decided not to worry about practical concerns
I've actually changed the roof lines a bit to make it more like my original sketch where they were brush strokes, and the profile isn't quite so aggressive. I'll post some more when I get a chance.
AJLynn is offline
Old April 16th, 2008   #10 (permalink)
amer abidi's Avatar
lolll.. 'my' phallus is only 140m long, and only 35m of which is cantilevered, supported by a250m 1mdiameter longsapn steel/cable structure... but then again, that's only when it's limp
But why dont you have a certain part or extension of the wavy band wrapping around or at least approaching the tower base.. IMO, that would provide not only visual access and invitation to visitors, but would also help in saturating both objects as one AND help you structurally with ground support.
just my 5 cents... =)
amer abidi is offline
Adriaan van Jaarsveld - WIP Koper Challenge #1 - WIP 51 April 25th, 2008 07:31 AM
Sketch & Toon wip gdrakakis Cinema 4D 0 November 24th, 2007 09:20 AM
Commercial Building - WIP nicnic Work in Progress (WIP) 13 March 13th, 2007 04:12 PM
Please C&C my WIP and offer vray tweaks to better it.... bover Work in Progress (WIP) 2 May 31st, 2006 06:59 PM
Victor LOBA - WIP Victor_LOBA Challenge #1 - WIP 6 March 21st, 2005 03:22 PM
