Autodesk VIZ Autodesk VIZ
Old April 13th, 2008   #1 (permalink)
Default Rendering a perforated steel facade...
Hi,
I'm going to be drawing up a building with a perforated steel facade, as well as consisting of a number of steel mesh/ grated floors and walkways. I do all my drawing in Autocad and then import the drawing into Vis to render. Is there a tool to set a transparency to a material for the perforations, similar to a bump, or will I have to model each hole?! I tried modelling the steel mesh floor and the file became so big it was unmanageable!
Quirky is offline
Old April 13th, 2008   #2 (permalink)
tanni's Avatar
Bangladesh  Send a message via MSN to tanni Send a message via Yahoo to tanni
Default Re: Rendering a perforated steel facade...
that depends, how much close to it or LOD. most of the case i use maps
1. defuse 2. opacity 3. bump. 3ds max has a good map to use in perforated material you can try.
www.dcl-online.com
tanni is offline
Old April 13th, 2008   #3 (permalink)
SandmanNinja's Avatar
I think Tanni is spot on - a map would be the easiest method.
-SandmanNinja
website
SandmanNinja is offline
Old April 13th, 2008   #4 (permalink)
Thanks. I was thinking to use a map, bu if viewed up close is there a way for the perforations to appear transparent? Sorry, I'm a bit of an amateur on Vis. The steel grate walkway is causing me most problems (see link for an idea of the type of material I'm after). It's quite important that gaps are apparent in the texture and that the depth of the grate is visible... Can this be achieved with a map?
http://www.usffab.com/usffab/images/USF6685.jpg
Quirky is offline
Old April 13th, 2008   #5 (permalink)
tanni's Avatar
Smile Re: Rendering a perforated steel facade...
opps, link doesn't work. Just take a look i think this will work.
www.dcl-online.com
tanni is offline
Old April 13th, 2008   #6 (permalink)
prodham's Avatar
yup - opacity mapping is the solution. all you need is a b&w map
prodham is offline
Old April 13th, 2008   #7 (permalink)
Great stuff. Thanks for your help. I've just had a play around and setting a map and then using a bump and a cutout in the material's special effects seems to do the job.
Quirky is offline
Old April 14th, 2008   #8 (permalink)
Claudio Branch's Avatar
I have a modeling approach that you might consider using. When your camera is right on top of the subject, you really need to go with geometry. A large mass of modeled grating can quickly become unmanageable, but it doesn't have to...
Modeling:
1. Create a plane and assign an appropriate number of segments to it
2. Convert the plane to Editable Poly and select all of the edges
3. Use EP's "Create Shape from Selection" (use linear not smooth)
4. Select the new shape and make it a renderable spline.
5. Adjust rendering parameters to appropriate proportions/scale
Optimizing:
1. Once you have the grating scaled, Display as BOX!
2. Create instances of a single grate and build as needed from one
3. Convert all grating to V-Ray proxy (Especially on large scenes)
Just ask yourself this - "How is this thing put together in the real world?"
Think about how anything you need to model would be built and then utilize the tools our software offers us to replicate the process digitally...
Happy Modeling....
Claudio Branch is offline
Price of V-Ray Stand Alone Version? GaryR50 VRay Render 45 April 2nd, 2008 10:57 PM
How to make perforated steel? Macpod 3ds Max 18 December 11th, 2007 02:30 AM
NEWS: ARTVPS Launch new Rendering Solution with Mental Images Jeff Mottle SIGGRAPH 2006 0 August 1st, 2006 09:41 PM
vray - rendering a distributed render using netwaor rendering seamus VRay Render 3 August 23rd, 2005 03:40 AM
Rendering Stainless Steel mesht General Discussions 3 April 7th, 2005 09:27 AM
