Name: Tiago da Silva |
Hi there. I am using Maxwell to render a building interior. All worked perfectly, until I get a more detailed version of the building.
With this new version, Maxwell simply won't render at all... it gets stuck when reading the MSX information, right in the beginning, when it opens the "Maxwell render" window. I am using 3DS Max's Standard material, and the model itself has only 5 mega. The Maxwell version is the 1.6.6. Do you know what's happening? I mean, I can render the same mesh in the same conditions with both Vray and Brazil r/s... Has Maxwell some restrictions to the type of mesh it can render? Any help is very welcome. Thanks in advance, Tiago |
I switched all materials by a Maxwell material, and I still get stuck when reading the MXS info...
It's not my PC, because I've tested it in two different ones, and I'm sure it's not a problem in the model, since I can render it with both Brazil r/s and Vray... I can also render each layer separately with Maxell, but not more than two layers at the same time (I tried to put the entire model in a single layer, but it didn't work either)... So it must be some peculiarity with Maxwell and the type of meshes it can render... Any other idea? Thx in advance Last edited by trcsilva; April 14th, 2008 at 09:07 PM. Reason: info added |
Actually, if I attach all my objects in a single, huge one, I can render my model...
What a deception... never thought Maxwell render could be so stupid... |
Name: Mark Richardson |
I've had similar problems when all my materials and textures were not in the very same folder... But it sounds like you have a different problem. Troubleshooting Maxwell can be a real pain.
Mark www.ragusmedia.com/portfolio_Web |
| Maxwell Render 1.6 Out Now | Jeff Mottle | CGA News | 0 | December 4th, 2007 12:50 AM |
| Maxwell - Maya batch render issue | mitchrichie | General Discussions | 7 | October 12th, 2007 10:07 PM |
| maxwell render | STRAT | Maxwell Render | 83 | July 13th, 2007 01:30 PM |
| New Maxwell licensing | AJLynn | Maxwell Render | 23 | April 27th, 2007 03:38 PM |
| Maxwell Render for FormZ | Ernest Burden | FormZ | 6 | August 25th, 2005 12:59 PM |
