Old April 17th, 2008   #1 (permalink)
Name: Aleksandar Petrovski
Macedonia
Smile Mental ray Vray Radiosity materials
Hi guys,
ive been doing rendering with radiosity, and know im starting to learn MR and Vray. I have a lot of pains adjusting the materials. The question is, do all materials work nicely with all rendering engines MR, Vray and Radiosity?
I have an impression thats not correct.
So, is it very important to know before you start working which engine your going to use, and is it easy to transfer from MR to Vray later?
And if you have some nice tutorials of making materials for ext/int. arch. scenes i would love to check them.
thanks
aleks84 is offline
Old April 17th, 2008   #2 (permalink)
manta's Avatar
Default Re: Mental ray Vray Radiosity materials
They can both use standard materials...however to make the most out of each render engine, each one has its own special materials which will work much better since they are designed to do so...they also have their own lights and cameras for the same reason...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old April 17th, 2008   #3 (permalink)
AJLynn's Avatar
mr is happiest by far when you use Arch&Design (not to be confused with Architectural) materials. Vray wants VrayMaterials.
I'd recommend choosing mr or Vray - it hardly even matters which - and learning it well before thinking about the other.
AJLynn is offline
Old April 17th, 2008   #4 (permalink)
Macedonia
Smile Re: Mental ray Vray Radiosity materials
As i understood there's no big difference between Mr and Vray?
Im surprised bcaz when i saw all those butons for seting up the vray it looked more powerfull than MR.
However im haveing trouble with MR, im having constantly a line in the horizon thats like small gradient, and second i cant add fog ...
How you do it?
thank you guys
aleks84 is offline
Old April 17th, 2008   #5 (permalink)
SandmanNinja's Avatar
Australia  Send a message via MSN to SandmanNinja
I'd consider some tutorials - there are quite a few for Mental Ray that come with 3DS Max.
-SandmanNinja
website
SandmanNinja is offline
Old April 17th, 2008   #6 (permalink)
Justin Hunt's Avatar
Dont make the assumption the just because one has more setting than the other it is more powerful. Both are very powerful and versitile.
I would also suggest learning one at a time to avoid confusion.
jhv
Justin Hunt is offline
Old April 18th, 2008   #7 (permalink)
MasterZap's Avatar
Name: Håkan Andersson
Sweden
Talking Re: Mental ray Vray Radiosity materials
How you do it?
thank you guys
The "line at the horizon" sounds like you are seeing the "Aerial Perspective" of the skylight system. This is a built-in fog feature. Go to your "mr Sky" and change the "10% distance" for more/less fog, or turn it off.
If you want to use the oldschool max Fog, be aware that many max effects are low dynamic range, and gets confused by the high dynamic range of the sun&sky rendering. You can solve this by altering the physical scale to something very high, so that even sunlight fits into the oldschool "0 to 1" trange. Set physical scale to about 80,000 should do it.
See my blog for more details on physical scale stuff.
/Z
MasterZap is offline
Old April 18th, 2008   #8 (permalink)
AJLynn's Avatar
Would you really want to do that? Max fog isn't really that special, wouldn't it be better to just render a ZDepth pass and do the fog in post, and not have to mess with the rest of the setup?
AJLynn is offline
Old April 20th, 2008   #9 (permalink)
Macedonia
About the fog, probably your right maybe its easier to do it in the post.
One more ,,tricky,, question to harass you with .
Tutorials for making the right materials ?! somewhere
Aleksandar the Great - the amazing Macedonian!!!
aleks84 is offline
Maya v. Mental Ray Shaders hd_leach Maya 3 May 9th, 2007 11:13 AM
Mental Ray and VRAY Scotty T General Discussions 3 February 25th, 2007 08:51 PM
vray tip for those using architectural materials crazy homeless guy VRay Render 17 September 8th, 2006 11:55 PM
Max 7 Lights with Mental Ray OllyNicholson 3ds Max 9 July 21st, 2005 01:13 PM
FROM MENTAL RAY TO VRAY Ramon Aranguren Finished Work 20 November 17th, 2003 08:55 PM
