Old April 17th, 2008   #1 (permalink)
Default recalc final gather after changing filter?
do you have to recalculate the FG solution, or if you are writing, when you change the render filter? for example from box to mitchell?
thanks
SgWRX is offline
Old April 18th, 2008   #2 (permalink)
Brian Bradley's Avatar
Default Re: recalc final gather after changing filter?
Hi Steve,
Changing the AA filters will not make any difference
to your saved FG Map.
Regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old April 18th, 2008   #3 (permalink)
thanks
SgWRX is offline
Old April 19th, 2008   #4 (permalink)
you can also change the Samples per Pixel and Spatial Contrast without having an effecting the Final Gather saved file.
Munz is offline
Old April 19th, 2008   #5 (permalink)
really?! a long time ago i posted something about doing FG calcs at low resolution and a small render size, like 1/4-4 at 320x240 as a memory/time saver. the response was yes, that's a good plan.
however over time, i started noticing that if i left the read/write option checked, but the freeze option un-checked, it looked like it was recalculating (much faster) based on the fact that i changed the sampling.. and on other occasions when i changed the render size.
so, i figured it made a difference. so just so i'm clear, you don't need to recalc (or, you can calculate then freeze) under these circumstances:
1. changing render output size (320x240 to 800x600)
2. sampling (1/4-4 to 16-64)
3. changing spatial contrast.
4. changing brightness/contrast in exposure control
thanks.
SgWRX is offline
Old April 20th, 2008   #6 (permalink)
Hi Steve,
This one DOES make a difference as MR uses the pixel
space to determine FG point placement. When time is
of the essence though, this 'trick' may be necessary.
Something like 800x600 to 1024x768 would not produce
any drastic change in FG solution though.
Regards
Bri
The MBM Blog
www.vrayelite.com
Old April 20th, 2008   #7 (permalink)
ok.
SgWRX is offline
Old April 20th, 2008   #8 (permalink)
Justin Hunt's Avatar
Also if you recalc with read/write on but Freeze off, mr will skip over any existing samples, thus making it apprear to calculate faster, howerver its not updating those existing samples.
jhv
Justin Hunt is offline
Calculating Final Gather cferman Scripts 1 October 26th, 2007 11:09 PM
Mental Ray, final gather and bucket artifacts AJLynn 3ds Max 10 June 20th, 2005 08:03 AM
Mental Ray / Final Gather / Buckets problem Ras Autodesk VIZ 12 April 29th, 2005 02:35 PM
MR Skylight and Final Gather nisus 3ds Max 6 February 3rd, 2005 12:43 AM
