Name: Tiago da Silva |
Hi there,
my question is about lights with the Maxwell render... does it have some special light I need to use? I can explain: I am using a photometric IES sun to light my scene. However, since inside my model is too dark, I tried to put some standard omni lights (or other photometric lights) inside it, but maxwell does NOT use these new lights when calculating the scene illumination... Anything I might be doing wrong? Thx, Tiago Last edited by trcsilva; April 20th, 2008 at 11:53 PM. |
Hi Tiago,
Maxwell doesn't use any of the Max light objects or the standard Max sun/sky system. To create a light, assign an emitter material to a low-poly object such as a plane, a sphere or a box that will represent your luminaire. There are emitter material presets you can use to get started. Also, Maxwell has its own sun/sky system.
| Strange Photometric web lights. | Q-Bix | VRay Render | 6 | March 5th, 2008 10:13 AM |
| IES Lights in Mental Ray | daveb867 | Mental Ray | 8 | February 16th, 2008 09:45 PM |
| IES lights | daveb867 | Mental Ray | 3 | October 9th, 2007 04:37 PM |
| Viz 4 Crashing problems | Showcard | Autodesk VIZ | 4 | February 15th, 2007 03:20 PM |
| photometric lights | kamikaze | 3ds Max | 8 | July 17th, 2005 10:21 PM |
