Go Back   CGarchitect.com > MAIN FORUMS > Salary & Industry Surveys
Salary & Industry Surveys This forum is where you will find the most current industry and salary survey information.
Old April 21st, 2008   #1 (permalink)
Onzki's Avatar
Philippines
Default Salary Range Query
hi, anyone knows salary range in Hong Kong, China & Singapore for architects/designer 4years minimum experience? thanks a lot!
Onzki!(tm)
Onzki is offline
Old May 4th, 2008   #2 (permalink)
Name: Anwar Fardullah
Singapore
Default Re: Salary Range Query
Hi
pls refer to this link for the Singapore region, as for architects, shld be around $3K to $5K with some years of experience
http://myjobstreet.jobstreet.com/pre...ner|000|sg||sg
mesht is offline
Old May 28th, 2008   #3 (permalink)
illegalalieninbeijing's Avatar
It greatly depends on which school you came from. If you are planning to work in these countries regardless of experience or professional affiliations from your home country ( if you are a registered architect or so ), you will get minimum wage ( for foreign workers ). Unless you are ultra talented / multi-disciplined and lucky enough with a good employer, chances are, you can command a little bit more.
illegalalieninbeijing is offline
Old May 28th, 2008   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
3k to 5k sounds scary. ......are those US dollars? i thought Hong Kong was one of the most expensive cities to live in.
travis schmiesing
crazy homeless guy is offline
Old May 29th, 2008   #5 (permalink)
Singapore
it's in Singapore dollars, yep it is scary. construction industry in this region is booming, more architects are needed and willing to pay such a price for a talented one. yes, for foreign architects, most likely u will get the minimum, unless you're someone...
hong kong still expensive to live in...and so is japan...sg is cathing up too..sigh not cheap to live in such cities now
mesht is offline
Old June 12th, 2008   #6 (permalink)
gasoline's Avatar
Thailand  Send a message via MSN to gasoline
I have worked in Hk about 3d visualization animation (My experience is 4 year)
Salary is about 15000-17000 HKD/month
But living cost is expensive,I paid for rent room about 5000 HKD/month
Hope this can help you for decide
gasoline is offline
Pls. Help me... I NEED AN ADVICE...REGARDING THE SALARY IN DUBAI... arlan General Discussions 10 February 11th, 2007 06:03 AM
Career Switch / Salary Expecctations?!? MLL Job Board 28 April 30th, 2006 02:25 PM
Salary Question? jophus14 Job Board 15 April 24th, 2006 03:30 PM
Salary Levels in Saudi Arabia ?? IUI Design General Discussions 7 November 23rd, 2005 04:17 AM
Salary range in San Francisco? pygoh General Discussions 4 October 11th, 2004 09:29 PM
