Name: Tiago da Silva |
Hi there. Thanks a lot for you help guys, but I'm facing a last problem with Maxwell...
I am supposed to make a quicktime VR movie with my model (something like a 360 degrees movie, made from 6 rendered images, projecting the model in a cube centered at the camera position). However, all the images rendered with Maxwell have their corners darker than the whole image, so I got a very ugly match band effect in my movie... In the image below, you can see a snapshot of the movie, where the three images of the top corner of the cube **should** be transparently blended. Any idea? Thx in advance. |
Hi Tiago,
In the MXCL console, there is a vignetting control. Set that to zero. If you saved your mxi files for each camera view, just reload them into the console with vignetting set to zero and resave your image files.
Do you know where is that option in the 3DS Max plugin?
In order to create a QTVR movie, I have to use Max, and I couldn't find the vignetting control on it... Thx again |
I mean, all I have is a text field which reads "additional MXCL flags". By executing "mxcl.exe" on DOS, I got that "-v:XXX" is used to set the vignetting value. I'll try that, and post the result here.
Thx again Last edited by trcsilva; April 22nd, 2008 at 09:09 PM. |
| Bright then dark spots at edges of room | gazbo | Mental Ray | 17 | June 24th, 2007 05:51 PM |
| MR: Example Images rendered with MR/max | nisus | Mental Ray | 6 | June 8th, 2007 01:11 PM |
| NEWS: ARTVPS Launch new Rendering Solution with Mental Images | Jeff Mottle | SIGGRAPH 2006 | 0 | August 1st, 2006 10:41 PM |
| stretched rendered images | d7man2000 | 3ds Max | 5 | January 27th, 2006 11:15 AM |
| How valuable are rendered images | gipper51 | General Discussions | 28 | May 17th, 2005 09:44 AM |
