Hi all,
I was trying to make glazing on a flat surface so I took the tiles map in the diffuse slot of A+D mi. Giving a thought that In the tiles grid one can be black lines to make the grid and the main component I will add a glass lume to make it a glass in between that grid. but i m not getting proper result from it i.e. the whole surface gets white. it renders purely white. I am using it with mr sun and sky photographic exposure. Another thing is I was first time playing with the lume shaders that too without any studies on it.
Regards: Sandeep (got a new machine) (Intel 5299-ws chassis, 2 X e-5420 , 500-XVN MB, 4 GB FBECC Ram ) |
Name: Jeff Patton |
You shouldn't mix a new material inside the diffuse map of the A&D material...especially one that has it's own raytracing like the glass(lume) shader.
For what you're describing sounds like you should use a blend map to mix the two materials using that tile map as a mask. |
Hello Jeff,
Thanks for the reply what i have done is taken a tiles map in the diffuse slot. made the grout color black and the second color of the slot of the tiles i have taken the glass lume shader. the issue is while rendering it gets full white no tiles grid i.e. grout nor the glass lume effext is coming. I have checked the UVW mapping and the tile size again it is coming right. if i render the same without GLASS Lume in the second slot and make it some color it comes out right but on adding glass lume my problem starts. Thanks again for your concern but I will take a few more time of yours for the same problem.
#4 (permalink) | |
Name: Jeff Patton |
The A&D material is doing it's own raytracing, then your glass(lume) shader is also raytracing/refracting inside the A&D material...not good. Not to mention the fact that because the glass(lume) shader is inside the A&D material it's being multiplied by the lighting in the scene...which if it's the mrSun/mrSky that's why your object turns white/overbright. Again, there are a few ways to do what you want...Personally I would do this: 1. Make a grout material. (A&D material 1) 2. Make a glass material (A&D material 2) 3. Place them inside a blend map 4. Assign a tile map to the blend map as the mask. |
As I understand it, Jeff understands it
The problem appears to be that you're sticking the Lume shader where it's not meant to be used. Instead make a Blend material and make one slot in the blend an A&D thin glass, and the other the mullion material. Make the mask a Tile (set the colors to pure white and black) and set UVW Mapping on the object. |
Thanks Andrew and JEFF,
I have now understood how i shall work it out. I will come back as soon as i finish it. thanks again
| fg gi and reflection in glass | SgWRX | Mental Ray | 0 | April 20th, 2008 09:16 PM |
| Glass material: which slot determine the glass color | smr_VIZ | Mental Ray | 9 | February 16th, 2008 10:24 AM |
| glass material: comparing Max vs VRay | smr_VIZ | VRay Render | 0 | November 26th, 2007 09:12 AM |
| tiles patterns | al_farooq | 3ds Max | 1 | March 9th, 2007 09:13 AM |
| glass reflections | jccloutier | VRay Render | 10 | July 25th, 2006 08:20 AM |
